.015 piston out of the hole???
Old Feb 3, 2004 | 03:16 PM
TA2SLOW346's Avatar
Default .015 piston out of the hole???
Anyone run a piston with .015 out of the hole?
I'm having problems with a motor and had to deck the block, well now the pistons are out of the hole .015. Im going to run a .052 or .058 head gasket to make up for the added piston height.
Is there any draw backs to running a piston that far out of the hole?
BTW its a nitrous motor.
Old Feb 3, 2004 | 04:25 PM
monkeyboy's Avatar
higher CR and PV clearance issues.
Old Feb 3, 2004 | 04:43 PM
TA2SLOW346's Avatar
Im not worried about either one of those since im going to be running a thicker head gasket. What im worried about is it bad to run the piston that far out of the hole????
Old Feb 3, 2004 | 07:58 PM
TA2SLOW346's Avatar
Someone has to have a idea???????
Old Feb 3, 2004 | 09:12 PM
DaleMX's Avatar
FWIW mine were .010 to .015 out of the hole stock.
Old Feb 3, 2004 | 09:23 PM
Jammer's Avatar
I would think a best case for nitrous is zero deck (have to consider squish/quench though) to protect the top ring and edge of the piston... but the best solution is to have the pistons shaved so you get desired deck height.... my machine shop wanted $8 per piston...said it was quick and easy!!!
Old Feb 3, 2004 | 09:25 PM
TA2SLOW346's Avatar
Well cutting the pistons down isnt an option. I've got $300 worth of coating on the tops of the pistons.
Old Feb 3, 2004 | 09:31 PM
9secbird's Avatar
no, its not a problem. i think i will be fine, the main thing is to have around .080 when all said and done
Old Feb 3, 2004 | 09:37 PM
Jammer's Avatar
Okay... You'll probably be fine, but maybe just a little less than "ideal".
Old Feb 3, 2004 | 09:41 PM
LOnSLO's Avatar
My nitrous pistons stick out .020. I am running a .064 copper gasket also. It is not a problem at all.
Old Feb 3, 2004 | 09:44 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
Mine stick out that much and then some
Old Feb 3, 2004 | 09:58 PM
TA2SLOW346's Avatar
What gaskets are you running? Anything o-ringed?
Old Feb 3, 2004 | 10:18 PM
LOnSLO's Avatar
Block is o-ringed. I am using the rubber coated gasket from Flatout Gaskets.
Old Feb 3, 2004 | 10:24 PM
TA2SLOW346's Avatar
did you have to have a a receiver groove cut in the heads? Got any pics of the gaskets? Or do they have a webpage?
Old Feb 3, 2004 | 10:31 PM
LOnSLO's Avatar
They do have a website. You'll have to do a google search, I lost the link. I don't have to have a groove cut, but I did anyway.
Old Feb 3, 2004 | 10:38 PM
LOnSLO's Avatar
Here ya go http://www.flatoutgroup.com/gaskets/techtips.asp.
Old Feb 3, 2004 | 11:32 PM
Jammer's Avatar
Learn somthin new everyday! Good thread.
