Help with cam please
Old Nov 16, 2010 | 09:11 PM
ss408truck's Avatar
Default Help with cam please
I has tsp 408 stroker 9.4 to 1 compression ratio with afr 225 heads and fast 102 intake and throttle body rite now I have the tsp magic stick 3 cam in the motor to break it in. I am going to turbo this setup running about 10 to 15 lbs of boost will this cam be ok or do I need to put another one in it. If I need another cam let me know what you recommend
Old Nov 16, 2010 | 09:58 PM
Always2Slow's Avatar
That cam was designed to be ran all motor. When running boost you need a cam with little to no overlap otherwise known as a blower cam. So yes you will need a different cam. I would put the correct cam in the first time around unless you like tearing down the motor and accessories.
Old Nov 20, 2010 | 08:41 AM
RARON455's Avatar
If you go a custom cam route, I have had two specced out by an extremely popular and smart guy named Geoff, I am not sure if he is a sponser on the site, so PM me and I will give ya his info, hes out of louisiana,,(now the cam guys know who I am talking about)
Old Nov 22, 2010 | 11:01 AM
ss408truck's Avatar
To the top
Old Nov 22, 2010 | 11:05 AM
01FbTaWs6's Avatar
That would be Geoff at EPS I would assume? Batten Rouge, Louisiana?
Old Nov 22, 2010 | 03:05 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
The Ms3 is not an ideal boost cam. It has too much overlap which would bleed off boost. The last boost cam I specced for a 408 was a 230/236 592/602 114 LSA +3. Lots of low end power to get you into boost and no overlap.
Old Nov 22, 2010 | 03:14 PM
SOMbitch's Avatar
And yes he is a sponsor. He specced my cam too
Old Nov 23, 2010 | 08:54 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
When you get some free time give us a call & we can discuss what your goals are. I bet we can help you put together a custom grind camshaft that will meet your goals.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
