4200 stall enough for a vindicator?
Old Nov 18, 2010 | 08:45 PM
01FbTaWs6's Avatar
Default 4200 stall enough for a vindicator?
Hey guys, a 4200 stall, 4.10 gear, 28 tire enough for a vindicator? Or do you think it will be lazy out of the hole? TH350 trans.
Old Nov 19, 2010 | 09:48 AM
Damian's Avatar
LSX Mechanic
That should be fine.
Old Nov 20, 2010 | 11:14 PM
chrs1313's Avatar
ss4000 with a sbe 346 pulling 1.291 60 fts...
Old Nov 20, 2010 | 11:22 PM
camz28arro's Avatar
Anything bigger or equal to an ss3600 should be fine, I would get a ss4000 like above just because of yank's quality and performance.
Old Nov 20, 2010 | 11:37 PM
01FbTaWs6's Avatar
ive already got an FTI 4200 converter. wont be going with any other converter manufacturer :-)
i actually opted for a different cam. 234/238 on XE-R lobes.
Old Nov 22, 2010 | 03:04 PM
98blueSScamaro's Avatar
whats your setup know ????
Old Nov 22, 2010 | 03:13 PM
01FbTaWs6's Avatar
Its going to be stock 241 heads, with valve job and some bowl/throat work. 234/238 .598/.605 on a 112 cam
th350 trans
FTI 4200 stall
4.10 rear gear in an S60
(planning on a 28 tall DR)
1 3/4 to 1 7/8 stepped headers, into a 3 inch ORY and magnaflow exhaust
full suspension car (lca's, relo brackets, chassis mounted tq arm, competition engineering rear drag shocks on 50/50, QA1 SA's on the front)
Some weight reduction (full a/c / heat gone, everything behind the dash, front sway and brackets, cc, abs, tcs)
