Lack of fuel?
Old Nov 20, 2010 | 05:19 PM
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
Default Lack of fuel?
OKay my 98 t/a has been acting up a lot lately. Wife tells me i should sell it and get another car....
Hear's the run-down. You can hear a popping noise coming from the tailpipe in the exhaust. Sometimes on cold starts it makes a slapping noise coming from back of engine possibly no. 7 cyclinder. Doesn't always feel peppy for a bolt-on ls1 f-body until above 3k RPMs. engine is bone stock and no aftermarket tunes.
Thanks
Old Nov 20, 2010 | 06:25 PM
anyone please...?
Old Nov 21, 2010 | 02:06 PM
help...?
Old Nov 21, 2010 | 07:26 PM
SOMbitch's Avatar
Start by getting codes/pending codes pulled or better yet get a tuner to look at things.....
Old Nov 24, 2010 | 05:27 PM
dash doesn't show any SES lights. it just feels like there's no low end tq, it moves once rpms go above 3500ish rpms. i'm workinge on finding someone to re-pin a 99 or newer pcm so i can buy a diablosport preditor. i have one for my 02 and love the thing so easy to use.
Old Nov 24, 2010 | 08:54 PM
Maas's Avatar
'Limp mode' codes won't necessarily throw a CEL.
Get a scanner, and see if there are any codes. Also try cleaning your maf, check your plugs, etc to eliminate those as possible causes.
Old Nov 28, 2010 | 08:54 PM
I did the plugs 2 months ago, there was one plug that had some oil on it... which was the driver back plug 7
Old Oct 27, 2011 | 08:32 PM
okay, so the car has been running normal, but now according to a GM tech2 it's misfiring and there's still a popping noise in the exhaust tone, could it be an injector starting to go bad? I don't get any SES codes/lights, just the noise. Someone mentioned possible burnt valve...
Any thoughts?
