tsp 231/237&pp 5.3 s2
Old Feb 4, 2004 | 03:41 PM
GrimReaper's Avatar
Default tsp 231/237&pp 5.3 s2
i just did long tubes, ls6 intake, stage heads and the tsp cam, with proper tune will i be able to be streetable?
Old Feb 4, 2004 | 03:50 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Yes. Absolutely. A4 or M6? I ask, 'cause stall or gears should complement the setup.
Old Feb 4, 2004 | 05:05 PM
Magred2001vette's Avatar
Also...Would one feel more low&mid range HP w/ a 224/224 cam over the 231/237, keeping the gearing the same on both. What are the caracteristics like of both cam under 2500RPM compared to a factory cam?
Old Feb 4, 2004 | 05:14 PM
!LS1 11 Second Club
I've had a 222/222 cam, and the 231/237 cam.
The 231/237 cam really shines up top, but is no slouch in the mid range. Only at the extreme low revs does it stumble (but then again, the entire power curve shifts up with the bigger cam - something expected).
My experience; the 231/237 pretty much mirrored the 222/222, but pulls much harder, and longer up top. The 222/222 had just a tad bit more torque available sooner (again -as expected).
