So it decided to die on me....
Old Nov 27, 2010 | 07:54 PM
OutToWinPAHC's Avatar
Looking at prints there is a 15A fuse that feeds the coil packs. So check your fuses.
If they check out, it may be a sensor or ECU.
https://ls1tech.com/forums/conversio...chematics.html
Old Nov 27, 2010 | 08:03 PM
babbage1109's Avatar
I checked all the fuses yesterday and they all passed in the engine bay. Could a nock sensor cause it not to spark?
No I would think crank or cam angle sensors.
Old Nov 27, 2010 | 08:14 PM
I threw the code reader on it and nothing came up. Sooo. I guess I'll try that. It can't hurt anything I suppose. The cam sensor is behind the intake manifold? As mechanically inclined as I am, I'm still learning haha.
Old Nov 27, 2010 | 08:17 PM
Well it wont throw codes yet not running, it will display generic codes. But the ECU uses those signal to fire out where it is and when to spark. Then uses those and other sensors to control the spark while running.
The cam sensor is located behind the intake manifold, and the crank PS is near the starter on the side of the block.
Old Nov 27, 2010 | 08:22 PM
I'll replace those tomorrow afterwork. And hopefully go from there. We'll see what happens. Thanks for the help
Old Nov 28, 2010 | 06:53 PM
I changed the crank position sensor today. Still no go. Soooo. I dunno.
Old Nov 28, 2010 | 08:38 PM
LaBLKv6Z's Avatar
That sucks man, did you try unpluging the MAF and see if it gets spark?
Old Nov 28, 2010 | 10:32 PM
Mhm. Everything that I can think of. I'm just going to get it towed. Let my warranty deal with it
Old Nov 28, 2010 | 11:02 PM
z99ls1's Avatar
Restricted User
Let us know what you find out on it
Old Nov 29, 2010 | 11:57 AM
freakyfastlsx's Avatar
that sucks sorry to hear that
Old Nov 29, 2010 | 06:25 PM
  #32
garygnu's Avatar
maybe its a bad crank sensor.
Old Nov 29, 2010 | 08:17 PM
  #33
ae13291's Avatar
so you had warranty the whole time?
Old Nov 29, 2010 | 09:14 PM
  #34
Well yes. I just hate dealing with the dealership. They take forever to do anything and half *** it. I rather do it myself if It's simple. But. It was the ignition relay. Again. I was checking over the fuses and i tried starting it. And yeah. Idk. New ignition relay and all is well. Thanks for the help.
Old Nov 29, 2010 | 10:32 PM
  #35
Whoops I should have asked you to check for power after I looked at the schematics. We were close.
Old Nov 30, 2010 | 09:17 AM
  #36
Haha yes we were I assumed the ignition relay was good since I replaced it so recently but I was checking for power in the fuse box and I guess just bumped the relay the right way I kept hearing it click. So I tried starting it and it fired right up. Replaced it and hopefully wont have anymore issues for a while. Thanks again for the help
Old Nov 30, 2010 | 09:06 PM
  #37
noah89's Avatar
The starter relay is right next to the ignition relay. On occasion mine goes out for no reason. I keep two spares in the glove box.
Old Dec 1, 2010 | 08:47 AM
  #38
I have a feeling I'm going to start keeping a spare or two around Now lol
