ss3600 or ss4000?
Old Dec 10, 2010 | 06:09 PM
  #41
TXZ28LS1's Avatar
somebody correct me if im wrong,
but doesnt an auto lose a bit of top end with a bigger stall? like i said as much as people are quick to say 4000 stall, ive seen a few cars run very small stalls. Like i said ive seen guys with 3600 stalls and smaller.. Heck, there was a guy running a 408 or 427 with a 2800 stall for the track..
Old Dec 10, 2010 | 07:27 PM
  #42
chrs1313's Avatar
that is the difference between a well built stall and a junkyard rebuild core...ever wonder why there is such a price difference between companies...
an aftermarket stall should not lose any topend ie mph...if anything it should gain, even the big 4000+ stalls will be as efficient if built right...
also look at what the guys with the smaller stalls run at the track vs the bigger stall guys...
I personally gained 1mph when I went from stock to the ss3600 and now with the ss4000 I lost nothing...I know fuddles used to be hit or miss, some lost no mph why others were dropping 2mph on the topend to gain in the 60ft...the $ difference is well worth it...
Old Dec 10, 2010 | 07:28 PM
  #43
SOMbitch's Avatar
Generally speaking the higher the STR the less efficient up top the stall will be. The trade off is a higher STR will hit harder off the line because it has more torque multiplication at the rated stall speed. Stall speed and STR are not related. Ex. my Yank SS3600 has a 2.5 STR and IIRC the Yank PT4000/4400 has a 2.2 STR and are VERY efficient up top.
Old Dec 10, 2010 | 07:43 PM
  #44
Detoxx03's Avatar
SS3600 here and it performs fine for the strip/street and highway pulls
Old Dec 11, 2010 | 01:05 AM
  #45
TXZ28LS1's Avatar
Definitely Dextoxx. Your car pulls like a monster.
I have a vig 3200. I have had it for 3 years now with no problems. Drives so much like stock. I talked to PI and their vigilante 3200 is really like a 34-3500 stall. I cant remember the STR as i had the cam and stall done at the same time.
I want to step up to a bigger stall. But i got plans on spraying and wonder if i should keep my vig 3200. The last few magazines ive seen with shops putting in a vigilante, it was either a 2800-3000 stall..
Old Dec 11, 2010 | 01:07 AM
  #46
TXZ28LS1's Avatar
I agree Chrs13.. you cant go cheap on a converter. Im running a vigilante. The car i was talking about with a 2800 stall was a car in GMHTP. He was running a Yank 2800 stall.
Old Dec 11, 2010 | 09:56 AM
  #47
chrs1313's Avatar
keep the 3200 vig if you are hitting it with the bottle
Old Dec 11, 2010 | 11:47 AM
  #48
*02WS6TURK*'s Avatar
4k for sure. I ran the 3600 on a old set up and could have easily got away running the 4000.
