block rear oil mod, learn from my mistake
Old 01-21-2011, 04:56 PM
  #81
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Originally Posted by Isolde
Chrome, you've already lost. You'd know that if you had read the first 3 pages of this thread. Being too lazy, or ignoring what you read if you did read it, just reflects poorly on you, and makes us laugh at you.
It is an interesting concept, but just that. Just because you're not seeing tons of oil there doesn't mean it isn't being pressurized throughout the block.
Old 01-22-2011, 06:02 AM
  #82
oneoverwrx's Avatar
We are going to do the cover and the block. My car wont run for a couple months but i will report back when it does.
Old 01-22-2011, 01:54 PM
  #83
s346k's Avatar
Originally Posted by LS1-450
What logic? Open up the passenger side valve cover, start the car & see for yourself. It's not a guess, it's fact.
that valve cover hasn't been off in over 10 years. i am not removing it at this point haha. i refuse to believe that any part of the engine lacking oil will last very long at all.
Old 01-23-2011, 02:04 PM
  #84
LS1-450's Avatar
Yah, well I still believe in Santa Clause. That doesn't mean that my reality matches the reality of others whom now where big boy pants.
This was a good/informative thread that is turning to **** by recent statements being made by people who are either uninformed or have not read all of the posts in the thread. In either case, this thread should be locked & made into a sticky.
Old 01-24-2011, 10:50 AM
  #85
racer7088's Avatar
Thumbs up
Originally Posted by Kaltech Tuning
What are you talking about erik, you've never seen the countless number of pass. side cylinder head and valvetrain failures due to lack of oiling????? I mean come on, it take minutes for the oil to get to that side. 35% of my business last year was replacing passenger side components in the earlier motors due to lack of oiling. LOL!!!
Yep I understand the concern for people that do not know as much about the LSx oiling system and if done correctly it probably isn't bad but the oil passage down the other side is huge already so the only thing limiting the oil at all over there on the passenger side bank is the front cross over but like we have all seen there does not appear to be any issues anyway from what I have seen. With much larger lifter clearances this mod will help a lil for sure but also take some oil away from the crank as opposed to making it go through the other side first.
Maybe since the opposing side has no main oiling drilled to it though it will also flow the other way around there and help oil the front mains a little better? You'd have to log oil pressure in a running engine at the front and the back with and without this mod and see what you get. Then you'd really learn something. From what I have seen so far still though it does not seem to be a big deal though.
Old 01-26-2011, 09:47 AM
  #86
TurdsOfMayhem's Avatar
Very interesting thread. It was a good read.
Old 09-27-2011, 11:26 AM
  #87
lemkerailroad's Avatar
Very good topic here....
I have a la motor I am getting ready to go through and was wondering how all this nodding to the oil system has worked out. Is their any issues out their now that you have run the engine for some time now.
Dave
Old 10-10-2011, 02:37 AM
  #88
35thAnniversaryPhil's Avatar
I still don't get it, is this a problem associated with only 97-98 LS1 blocks or is it all LS1 and LS6 blocks?
Old 10-10-2011, 11:36 AM
  #89
LS1TECH Sponsor
Steve - Race Eng's Avatar
Default oil channel
Only the early LS1 blocks lack the channel as well as all of the iron truck blocks. The LS6 and later LS1 blocks, most '99 and newer, have the cross channel in the back.
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old 10-10-2011, 12:13 PM
  #90
82cetuner's Avatar
I would of just used a old gasket to begin with, it would take the abuse of the slips, show you the correct areas to grind all at the same time.
Old 10-11-2011, 12:38 PM
  #91
Steve
Ah perfect! Thanks for clearing that up Steve.
Cheers
Old 08-31-2013, 06:58 PM
  #92
IRNMADN's Avatar
Sorry to bring this one back from the dead, but....
I have both an early LS1(97' C5) and an 04' 5.3L out of a Yukon.
What ever happened to this? I found this article that points out to not use the early LS1 engines for high performance apps, is this the same thing this photo shows?
http://www.hotrod.com/howto/113_0504.../photo_06.html
And if this was really an issue, seems the aftermarket would have just came out with a better rear cover with the channel built into it.
Old 08-31-2013, 09:28 PM
  #93
427
427's Avatar
That rear channel is not a problem, the early blocks had other things that make them less desirable.
Kurt
Quick Reply: block rear oil mod, learn from my mistake
