General Piston Question
Old Dec 9, 2010 | 01:29 PM
T-Pat's Avatar
Default General Piston Question
I've done a little research on this subject myself but haven't found much so I'm going to ask you all. Is there any other benefits to running a hypereutectic piston over a forged one besides price? I'm getting ready to build another engine and I'm contemplating putting hypereutectic pistons in it.
Thank you!
T-Pat
Old Dec 9, 2010 | 04:17 PM
1994z's Avatar
daily driver, street/strip with up to 150 shot will be okay, as long as you know what you are doing with the nitrous.
Old Dec 9, 2010 | 04:34 PM
Silvy6.0's Avatar
x2.....
Old Dec 9, 2010 | 04:56 PM
KCS's Avatar
KCS
Moderator
The hypereutectic aluminum doesn't expand as much as forged 2618 or 4032 aluminum, so you can usually have a tighter piston-wall clearance than with a comparable forged piston. This mainly keeps the engine quiet and slightly reduces wear.
Old Dec 12, 2010 | 10:16 AM
T-Pat's Avatar
Well I'm building 10.0 comp 496 with peanut port heads and a relatively mild cam (by big block standards) with no nitrous. It'll see a lil track time but not much at all. Will hyperuetectics be fine with that? I kno this an ls1 forum but I was just curios
Old Dec 12, 2010 | 10:29 AM
KCS's Avatar
KCS
Moderator
Yeah, they'll be fine with that, just as long as the engine was built and machined correctly. You can have a badass $1000 set of pistons, but something like piston-pin clearance can screw everything up.
Another thing is keep an eye on the weight of the piston. I got some cheap 4.030" hypereutectics for a Ford (the ones that come in a Summit rebuild kit) and they were ridiculously heavy. IIRC, they were ~700g with the pin!
Old Dec 12, 2010 | 10:38 AM
T-Pat's Avatar
Wow those are way to heavy for that small of a piston! Did u end up running them or opting for a different set?
Old Dec 12, 2010 | 10:46 AM
KCS's Avatar
KCS
Moderator
I haven't decided yet. I did all of the machine work already, so it can go together tomorrow, but the idea of having those bricks in there might keep me up at night, lol. It's going into a truck anyways, so it probably won't ever see over 5500RPM.
