806 vs 243 valve sizes?
Old Dec 13, 2010 | 01:03 PM
LS1FREEK's Avatar
13 Second Truck Club
Default 806 vs 243 valve sizes?
I have a 98 Vette with them factory crappy *** 806's, lol, and I bought a set of BARE 243's. Well I want to swap the valves from my 806's, as far as I know, they have the same size?
Old Dec 13, 2010 | 03:09 PM
02*C5's Avatar
I think that the valve runners on the 243/799 are a tad bit longer to accommodate the LS6 valves. You can't run the LS6 valves on any other head because they are a little longer than regular length valves. Do little more research before doing the change over.
If am wrong some one will correct me.
Old Dec 14, 2010 | 08:56 AM
LS1FREEK's Avatar
Hmm... That makes sense...
Anyone else?
Old Dec 15, 2010 | 08:11 AM
LS1FREEK's Avatar
Ok, I read somewhere on another site, that the Ls6 valves are approximately .023" longer. Does this mean that the entire valve sits closer to the deck keep the same valve stem height as a regular ls1 head, or are the valve stems sitting .023" taller? If so, that would explain why the Ls6 cam has a smaller base circle and still run 7.4" pushrods...
Old Dec 16, 2010 | 11:58 AM
LS1FREEK's Avatar
TTT... Someone's gotta know...
Old Dec 16, 2010 | 12:43 PM
HAZ-Matt's Avatar
If I remember correctly, only the 02+ hollow and sodium valves are actually longer than the LS1 valves. That was in fact so they could shrink the base circle more while keeping what they considered good rocker geometry.
The 01 LS6 and LS2 valves are the same as the LS1 valves, as in same part number and everything:
Intake: 12563063
Exhaust: 12563064
Old Dec 16, 2010 | 01:13 PM
SSmoked1's Avatar
qygda
Old Dec 16, 2010 | 09:27 PM
TA6spdRDC's Avatar
i have a set of 853s and a set of 243 none ls6 heads and i took the valves out of both sets of heads and they look the exact same size.
Old Dec 16, 2010 | 10:12 PM
LS1FREEK's Avatar
Cool, thanks for the info guys!
Old Dec 27, 2010 | 10:54 AM
mamead's Avatar
So I am still confused. I have 806 heads on my 98 T/A. I am planning to swap over to 243's this winter/spring. If the 243's are bare, I'd HAVE to buy new longer intake and exhaust valves to work and could not just swap them from the 806's over to the 243's?
Old Dec 29, 2010 | 04:03 PM
LS1FREEK's Avatar
Negative, if you swap the valves from your 806's to the 243's, your valvetrain geometry will be exactly the same as the 806's originally were. If you were to take a set of the hollow/sodium filled LS6 valves and put them into the 243's, you would need shorter pushrods.
