Slp Double Roller Chain Issue..VIDEO INSIDE!!!
Old Dec 17, 2010 | 10:56 PM
Greekey's Avatar
Guys I got the son of a bitch on finally. Can anyone tell me if my timing adjustment looks okay? Does it really matter if they are off by like 1 or 2 degrees? You can see in some of the pictures that I measured the area behind the crank gear and it was 3 inches long. So I put a mark at 1.5 inches for straight up and down with the crank gear.
Old Dec 17, 2010 | 10:59 PM
soundengineer's Avatar
Heating it up with a Heat gun does not work..LOL
thats a funny one.. I gotta remember that for the same comments as Blinker Fluid and Muffler Bearings
you have to put both on at the same time...and it helps to start with it slightly off so you can get a bolt started...Just get the dowell in the right spot all lined up and it will pull itself on when you get the 3 bolts started...
you cant mis-align the dowel if you get it on the correct link and can get all 3 bolts started...
Just make sure you get both gears pulled all the way on before you snug down the bolts on the cam.
the tightness on the double chains are both the pro and the con for it...
benefit because you dont have any slack and you never will, con because it makes it a little tougher to put on...has to go on exactly straight and both gears exactly at the same time.
Old Dec 17, 2010 | 11:02 PM
IF you are at 2 on the crank pin, and 3 on the dot.. then you are not lined up and you will be at 2.5*
you are a tooth off...
it wont hurt anything mechanically most likely... but its not 2* like I think you are shooting for
Old Dec 17, 2010 | 11:05 PM
Greekey's Avatar
My crank pin is in zero slot...Not 2. Its zero to zero.
Old Dec 17, 2010 | 11:22 PM
sorry.. I didnt look close enough at the picture... couldnt see the #'s on the teeth at first....
Loosk correct then if you are at 0 and 0
Old Dec 17, 2010 | 11:44 PM
LilJayV10's Avatar
Yes. Yes I was. LOL.
Old Dec 18, 2010 | 04:14 AM
LilJayV10's Avatar
From the pic it, it looks like the cam gear is right, if the tooth on the crank gear it's pointed to is 0 then yes are dot to dot.
If you are going dot to dot then you are good. If you are checking the ICL I can't say without a degree wheel.
I had a cam custom ground for my car and ended up using an offset bushing to get the ICL right. Well it was suppose to be 110 and I ended up with 109.5.
Depends on who you ask if that makes a difference or not. Hell after you start the car and run it for a few hundred miles the chain is going to stretch some. So what is the initial measurement worth then?
That I don't have an answer for. You'd have to ask Damian, Tony M, Pat G or on of the other guru's on here because I don't know.
Old Dec 18, 2010 | 04:15 AM
LilJayV10's Avatar
Also, have you turned the motor over a few times and re aligned the dots?
Old Dec 18, 2010 | 07:46 PM
studderin's Avatar
really hard to see the dot on the crank gear tooth. you can see it in the 1st pic with the flash, but not the others.
Old Dec 18, 2010 | 08:02 PM
Greekey's Avatar
There isn't an actual "dot" there is a number zero...You can see it in the third picture vary faintly.
Old Dec 18, 2010 | 08:45 PM
O2Form's Avatar
Be sure you have some slack in that chain, if you don't its going to play hell on your bearings.
Old Dec 18, 2010 | 08:46 PM
  #32
O2Form's Avatar
How do you know if it works...you ever try it? I'll bet you never even used a heat gun!
Old Dec 18, 2010 | 09:02 PM
  #33
Hanzy98LS1's Avatar
Hay bud a lil off topic but what oil pump are you using?
Old Dec 18, 2010 | 09:26 PM
  #34
Greekey's Avatar
Slp Oil Pump
