Slp Double Roller Chain Issue..VIDEO INSIDE!!!
I have had this problem installing double rollers on SBC's. What I have had to do is not push the crank gear on all the way and walk it forward as you put it on the cam. With the double roller sometime there isn't enough slack in the chain to have the crank gear on all the way and not the cam gear. I hope that made sense.
Man unless someone has a different idea, then probably yes.
I just did my first LS H/C/I swap on my bird this year. I have worked on dozens of SBC's, LT1s, Pontiac's and have had this problem. I say this not to fluff my feathers saying I am some great mechanic because I don't think I am. What I am saying is I have seen it on many different engines and there is only one way I know of to install it without damaging anything.
With the dowel on the cam the cam gear has to "rock" forward so to speak to get the gear on.
With two rows of links on the double timing chain the chain can't flex, bend, however you want to say it, forward to back enough to get the chain on.
I have in the past, put a small round screw driver in one of the holes through the gear into the cam opposite side of the dowel and smack the side of the dowel, lightly, with a small hammer.
IMO, this is not the best way to do it. You can mess the dowel up or the threads in the camshaft.
I would get some insight from some other people before listening to me. That last thing I want to do is lead you don't the wrong road on an LS engine.
At least, that's what I gathered from peoples posts in this thread. I'll be installing an SLP double roller + SLP oil pump too so this is useful info...
I kind of got lucky. Mine slid right on without any problems and was bolted up within 2 minutes.
this works some times. just get the dowl pin started, with the upper gear off the cam hub still. (use some thick lube hold the touringtion bearing in place) the cam will turn clockwise a little to lower the pin hole to the crank. and use a waterpump bolt into the cam, you have to be careful not the cross thread it but the cam in billet and strong. You can use the WP bolt as some leavage to get the upper gear up on the cam hub, you almost dont have to thread the bolt in much, just get it in the front of the hole. And rock it up and get the upper gear one the cam hub, and hand thread one wp bolt in.
if not your gona have to get the pump off and get the lower gear out a 1/4 to the chain is alined better. its gona be on tight.
Pull the crank gear back some, put the chain on both gears, make sure they are dot to dot, start walking everything towards the block, once you get the cam gear on the dowel it will be easier. However make sure the cam doesn't spin. This is where you can use a small screwdriver or punch to help keep the bolt holes lined up. You might have to use the screwdriver/punch to turn the cam once the gear is flush against it. Put the bolts in and tighten them down evenly. Spin the motor over a couple times to verify the dots are lined up. I personally put blue loctite on the cam bolts to a little added insurance.
I am sure you won't have any problems once you get everything lined up.
why not? you don't think the chain is gonna get hot and bigger when its running OF COURSE IT IS! I would try it before taking it back apart, its easy to heat that chain up, it will grow ALOT. Just heat evenly from one side to the other till its about 200 f, it will fall on.
I hope you are kidding? It aint a blow torch, its a electric heat gun. The air coming out of it is around 1000 degrees.
http://www.amazon.com/1500-Watt-Dual...2643542&sr=1-2
