rockers on stroker motor
Old Feb 6, 2004 | 10:26 PM
Slowverado's Avatar
Default rockers on stroker motor
what are most of your guys with big cube motors running? stock style rockers or rollers like the Y/T or comp setups? i'm figuring most are running a roller setup since it costs so much to build a motor that would be a bad spot to spare an expense. i was thinking of using the comp 1.7 ratio rollers when i finish my big motor. just wanted to see what everyone else was using.
Matt
Old Feb 6, 2004 | 10:40 PM
Jammer's Avatar
I rarely hear of stocker problems, though I'm sure there are some.
Old Feb 7, 2004 | 12:53 AM
TApimp's Avatar
i owuld run some comp 1.75;s
Old Feb 7, 2004 | 12:56 AM
Slowverado's Avatar
would you now? weird, i know a guy here that has a set for sale. but he's such a douche bag i don't know if i should buy them from him.
Old Feb 7, 2004 | 01:00 AM
Jason99T/A's Avatar
I can shift faster than you.
I'd have no problems running stock rocker on that type of motor.
Old Feb 7, 2004 | 09:19 AM
SDB's Avatar
SDB
I have a 382 stroker MTI built, it has stock rockers. For most applications stock rockers are fine (per MTI and LPE). Only if you have some nasty solid roller set up or a real nasty high rpm hydrolic roller set up would you actually benefit from shaft mounted ($$$) rockers. unless your making 550+rwhp N/A or if you plan on running high rpm all the time (i.e. serious autocross/open track stuff) use the stock ones. aftermarket ones may give you about 5 rwhp, not woth the expense.
Old Feb 7, 2004 | 09:38 AM
Country Boy's Avatar
Senior Member
Oh really? I hope your not refering to me
Old Feb 7, 2004 | 11:08 AM
steve-d's Avatar
SDB wrote: ....if you plan on running high rpm all the time (i.e. serious autocross/open track stuff) use the stock ones. aftermarket ones may give you about 5 rwhp, not woth the expense.
Actually above the use for track, they should show more than 5rwhp. I just obtained the Harland Sharp roller rockers. I'll post the dyno numbers after the installation. Hopefully, there'll be a double digit improvement.
Regards
Steve
Old Feb 7, 2004 | 10:09 PM
Slowverado's Avatar
country boy....nonono, TAPIMP has been trying to get me to buy his comp rollers....he was throwing in a shamless sales pitch there. i.e. he's the douche bag.
Old Feb 7, 2004 | 10:16 PM
Senior Member
LOL... cool deal. I was wondering because Im selling mine too
Old Feb 7, 2004 | 10:46 PM
Slowverado's Avatar
how much do you want for your's?
Old Feb 7, 2004 | 10:49 PM
Senior Member
https://ls1tech.com/forums/showthread.php?t=134597
