Another ARP Rod Bolt Nightmare
Old Dec 26, 2010 | 06:37 PM
COPO9560's Avatar
PS LS1450, it is incredible that theses engines are monsters hidden in small blocks but its also even more incredible that racing teams are creating 1200+hp out of little 2.0l engines N/A. [/QUOTE]
What teams are doing this?
Formula 1 engines, now limited to 2.4 liter V8's, "only" are capable of around 750 hp and that is near 18,000 rpm. These are among the most exotic NA engines made. If there is a way to get nearly twice this power with smaller displacement, I'd like to learn more.
Old Dec 26, 2010 | 08:47 PM
Yahelou's Avatar
Originally Posted by LS1-450
Those of us who "get away with it" do so because the bolts are swapped correctly. One @ a time while the other side remains torqued.
Originally Posted by Fb0dy0nly
Yeah Id have to agree. If you are planning on not honing after and checking the work you have performed on your expensive motor then at least install them this way as it would be the most proper in keeping the true bore size and not throwing it off as much as completely removing the bolts first. Also, make sure your torque wrench is accurate, its an easy thing to forget
i dont understand why ur assuming i installed them incorrectly. i do everything meticulously, just because i worry too much if i dont. i did my research before i started on it. i did each bolt one at a time, used the appropriate lubricant supplied, and torqued them using the same sequence everyone else has done. im just one of the unlucky guys that didnt work out for me.
oh and torque wrench was brand new from Lowes.
Old Dec 26, 2010 | 08:48 PM
Yahelou's Avatar
Originally Posted by krissoto
Very unfortunate disaster. GL with your next build
Originally Posted by Grimes
I'm sorry that you had the bad experience. But as you mentioned "most" get away with it. You're obviously not in the "most people" category! I'm sure you'll build an even better engine - goodluck!
thanks for the support guys.
Old Dec 27, 2010 | 10:31 AM
KCS's Avatar
KCS
Moderator
I ask again, how do you know? This isn't the first time someone has swapped the rod bolts out "correctly" and ended up with spun bearings. The common denominator I always see with people who have swapped to ARP's and blown their engine up is that none of them resized the rods like ARP recommends in their instructions.
The only correct way to swap out the rod bolts is to resize the rods. If you don't want to follow ARP's instructions, why even worry about using a torque wrench or stretch gauge? Just tighten them with a box end wrench until they feel tight. Just be sure to do one bolt at a time...
Old Dec 27, 2010 | 11:02 AM
rickyzZ28's Avatar
Sorry this happened to the op, but I do have one question.
If you are taking a motor out and putting new bearings in it and using Katech bolts would it be a good idea to have a machine shop check them or if I simply plastigauge them is that good enough.
Old Dec 27, 2010 | 11:56 AM
KCS's Avatar
KCS
Moderator
Plastigauge won't tell you if your housing bores are round, they can only measure bearing clearance. A machinist will have the bore gauges to accurately measure how round the bores are (or aren't).
Old Dec 27, 2010 | 06:15 PM
LS1-450's Avatar
Up 'till this post, you had not said that they were changed 1 @ a time. If this is the case, it's the first I've heard of anyone having a failure after carefully swapping one @ a time. Still, it sounds like the failure was caused because one or more of the bolts had worked its' way loose. Is that the case? If so, it makes no difference that they were done one @ a time, 'cuz they were not tight enough & the becoming loose is likely what has caused the problem.
Old Dec 27, 2010 | 06:28 PM
LS1-450's Avatar
Sorry for the double post. I forget to multi-quote & then remember that there was another comment that I want to reply to. This leads to a double post.
The statement is related to what us garage mechanics are able to do with them. Relating an F1 2.4L build & budget to a 5.7L LS build & budget is just plain silly. Yah, the F1 stuff is incredible, but not something remotely possible for those of us without an unlimited budget & a fully staffed engineering department. To me, trying the to compare the 1200 HP of a 2.4L F1 engine to a 500+ HP 5.7L LS engine takes ricer math. We all know that ricer math makes about as much sense as milkin' a duck.
Old Dec 28, 2010 | 02:32 AM
Slick87Rush's Avatar
Yeah I just put a set of arp bolts in today .... Kcs I correct in distortion due to more clamping force... I had two rods out of round in my 6.0 one was junk the other hones out .02 you spin rod bearing when the big end is oor! you really need the rods resized if you go with an aftermarket bolt. I'm glad I decide to resize. Price of mind at the least.
Old Dec 28, 2010 | 03:13 AM
Daryn's Avatar
Formerly darynC-10/23/10
yep arp bolt are cheap insurance. until you have to buy a new motor 3000 miles later. thats why im not touching my ****.
Old Dec 28, 2010 | 12:06 PM
Yahelou's Avatar
yea I agree, the failure was caused by one of the bolts working its way loose. but i torqued down everything correctly, im sure of that. i passed over them twice with torque wrench to make sure they were accurate. oh well, **** happens. i may have done them incorrectly. who knows.
if anyone knows, what is the difference between the katechs and ARPs? is the design/material different?
Old Dec 28, 2010 | 01:18 PM
  #32
LS1-450's Avatar
You see, that's where I also have a problem. Unless the elongation, tensile, yield strengths of the Katech & ARP bolts are very different, there should be no advantage from one to the other.
To those commenting on the re-boring. I have not said that re-boring isn't the best solution. What I've stated is that by replacing one bolt while the other is torqued, should be enough & has always been enough when I have swapped bolts, as well as many others.
Old Dec 28, 2010 | 02:11 PM
  #33
SILVERBIRD97's Avatar
I have found in personal experience that the ARP PRO SERIES (pn:234 6301) rod bolts take so much torque to get proper stretch that they do in fact distort the rod. But the ARP HIGH PERFORMANCE(PN:134 6006) rod bolts are strong enough for a stock rod upgrade, but not so strong they distort the rod over .003. I have personally put 3 6.0's and 2 5.7's together with stock pistons,stock rods, stock crank, and ARP high performance rod bolts and have no problems. We turn them 6700-7200 rpm and all 5 motors have well over 10,000 miles on them. But.....I will agree that checking for rod distortion with a set of ARP's is definatly worth the extra effort!!!
Old Dec 28, 2010 | 08:15 PM
  #34
DaveX's Avatar
As a machinist/tool and die maker, I would have zero confidence in the rods being round after swapping rod bolts without resizing no matter what method you use to do it. Someone should do a test; size rods with factory bolts, then swap them for any other bolt and indicate them to see if they are still round. I'm betting not.
It doesn't sound like this is the reason for this failure however.
Old Dec 28, 2010 | 08:37 PM
  #35
FDLS1's Avatar
I have been a machinist for 16 years and having used ARP pro series bolts I would do it again without thinking twice. Tell me how you are going to check the bore on the rods after installing the new bolts? another question, if you wanted to check, why bother going through all the trouble to replace the bolts anyway? just leave the stockers in there. To replace the bolts and check the rod bore at the same time you must have the rods out of the block to do it properly.(buy a new motor from a reputable shop) Also answer this, take a single rod, put the bolts in, bore it or hone it so that it is perfectly round(BTW I grind mold components all day within 0.0002), then take the bolts out, reinstall the bolts you just pulled out and remeasure...I'll bet the rod is now out of round.
Good luck to you guys, untill you learn how to measure correctly or remember just because you just bought a new torque wrench it doesn't mean it is working correctly.
Old Dec 28, 2010 | 09:32 PM
  #36
KCS's Avatar
KCS
Moderator
With a dial bore gauge, of course. You check the diameter at 12 and 6 o'clock, and then work your way around to see if the diameter changes. I hope after 16 years of machining, you already knew this.
Exactly. ARP's instructions say to resize the rods, so I don't know where the idea came from that you could just swap them out in the car and everything will be fine and dandy.
Why would that be necessary? Some people only have a budget to rebuild with stock parts, or an oversized piston at most. Not everybody has the $3600 or more to buy a forged shortblock. $75 for the bolts and then another $80 to resize the rods is an attractive alternative to aftermarket forged rods that cost anywhere from $250-1000.
Answer what? You didn't ask a question. But I'll ask you a question: why would the bore be out of round? I have already resized a couple GM LS1 rods with the ARP bolts and when I finished with them, they were round. They were still round when I checked them after I disassembled and cleaned them as well. What if you loosened only one bolt at a time?
Thanks, good luck to you as well, until you learn that doing something for 16 years doesn't mean you're always right...
Old Dec 28, 2010 | 09:43 PM
  #37
The Alchemist's Avatar
UNDER PRESSURE MOD
I know you said you bought a new torque wrench at Lowes, but I'm guessing it wasn't calibrated, and with any measurement instrument, it's only as good as it's last calibration.
So maybe it was off and you only got 30-40 ft/lbs instead of 50, we'll never know.
Sorry to hear about your misfortune.
Old Dec 28, 2010 | 09:55 PM
  #38
tittan1500's Avatar
When I had my rod bolts swapped the engine builder said the clearance was not proper with the new bolts so they were resized.
Old Dec 28, 2010 | 10:27 PM
  #39
DaveX's Avatar
That is exactly what I'm talking about, someone should try it. I have spent many hours running a jig grinder and I agree, they will not be round. When you take a motor with some miles on it and simply swap bolts they will be even further out of round.
Old Dec 28, 2010 | 10:42 PM
  #40
HOLY ****!!!! This has turned into a bashing of each other instead of a discussion. I'm outta here. Taking my ARP's with me!!!
