heads
Old Dec 27, 2010 | 07:51 PM
kjmj's Avatar
Default heads
So I have a set of 243 heads now (not on the car). My builder is pushing me towards an upgrade. Should I look at the 5.3 stage 2.5 or stage 1 ls6 heads. It will me matched with a torquer 2 cam.
Old Dec 27, 2010 | 08:09 PM
garygnu's Avatar
the TSP heads are on sale,I would get the stage 1 ls6 head.
Old Dec 27, 2010 | 08:11 PM
Lincolnman's Avatar
I don't have your answer, but you may want to give more information.
What level are you shooting for, what type of racing (if any) and what weight of vehicle all seem pertinent.
Old Dec 27, 2010 | 08:19 PM
MyFirstLS1's Avatar
agreed depending on your goal cant really help much
but i am doing that same head/cam build. (as for machining i am only getting them milled.) Getting them leak checked and checked for cracks to. Hoping with supporting mods it will bring me right up to 400hp for a dd.
Old Dec 27, 2010 | 10:19 PM
kjmj's Avatar
sorry for the lack of info. it is just a weekend cruiser. i get to drive it maybe once a month. will have zero track time. i am not looking for the fastest car around just something to have fun with. my builder just said he has seen it a thousand times, so we should just get heads to start with. a4 c5 will have a torquer 2 and a 3200 stall.
Old Dec 27, 2010 | 10:36 PM
wickedbluess's Avatar
i ran stock 243s with torquer v2 and put down a lil over 400. if you have the cash just go for the stage 1
Old Dec 27, 2010 | 10:54 PM
kjmj's Avatar
Any down side to the 5.3 heads? The flow numbers actually seem to be the same if not better than the stage 1 ls6 heads.
Old Dec 28, 2010 | 08:00 AM
reeperz28's Avatar
I've seen average 420 430 ish range with the 5.3 heads with tsp cams. But if you have 243's already.. Why not send them off to get ported and polished ? T.e.a does black magic on there sent in ported heads I would check them out and I've seen A.I do wonders on 241's
Old Dec 28, 2010 | 09:25 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
With their larger valves, they do actually outflow and perform the Stage 2 LS6's. But, as someone said, since you have stock 243's already you could send those to us to have us port them and save some money and get better performance!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Dec 28, 2010 | 03:33 PM
about how much does it run to have a set of heads sent it to have them ported? say some l92s?
Old Dec 28, 2010 | 03:46 PM
NC98Z's Avatar
So your saying the 5.3 heads out perform the Stage 2 LS6s?
Old Dec 28, 2010 | 03:48 PM
No, I'm sorry...I meant Stage 1 LS6's...I'd prefer the Stage 2.5 LS6's over the Stage 2.5 5.3L heads. Sorry for the confusion!
__________________
Old Dec 28, 2010 | 03:49 PM
http://www.texas-speed.com/shop/item...=1066&catid=40
$899.99 for the CNC porting and valve-job. Then you have the options for valves and spring towards the bottom of the page
__________________
