Cam Question DYNO PROBLEM
Old Jan 1, 2011 | 08:10 PM
d2camaro's Avatar
Default Cam Question DYNO PROBLEM
So i have Comp CAMS XER287HR-12 IT STATES.
VALVE TIMING @.006 INTAKE TIMING OPEN 34 DEGREES
SO AT .006 ON DIAL GUAGE AND ON MY DEGREE WHEEL I HAVE 28 DOES THAT MEAN IM RETARDED 6 DEGREES? I HAVE A 9 WAY ADJUSTABLE TIMING SET AND I INSTALLED IT DOT TO DOT IS THIS NORMAL AND IS A GOOD IDEA TO RETARD IT SO I CAN GET INTO SPEC WITH CAM CARD.
I AM DEGREEING THE CAM BECAUSE I HAD IT DYNOED AND WE HAD A PROBLEM WITH THE ENGINE GOING LEAN AT 3000rpm ON THE DYNO.THE TUNNER TRYED TO ADD FUEL AND TIMING AND TOOK SOME AWAY, BUT HAD NO LUCK FIXING THE SUDDEN LEANING PROBLEM. HE GOT IT TO GRADUALY PICK UP TROUGH THE POWER BAND AFTER THE LEANING AT 3000rpm .AND THE MECHANIC SAID THE HEADERS STARTED TO GLOW RED ON THE DYNO AT 3000rpm AND WENT CHERRY AT 5900rpm,SO THE TUNNER RECOMMENDED ME TO CHECK THE TIMING CHAIN PLACEMENT AND HERE I AM.
Old Jan 1, 2011 | 10:37 PM
jt76's Avatar
omg that hurts my head to read..
I have never heard of the headers on an LS1 going cherry red. I suggest finding a different tuner.
Old Jan 1, 2011 | 11:33 PM
C/Performance's Avatar
Here somethings to check for:
Headers red hot: Rich fuel condition - fuel burning in your primaries. Can be caused by un-metered air being pulled in downstream of your MAF, dramatically retarded timing, low spark intensity (incomplete fuel burn)..."
Our experience is that,we seen a couple GN buicks on the dyno and the headers would glow red because the timing was so retarded at wot.
Old Jan 2, 2011 | 06:49 AM
Jtm2085's Avatar
When I went to dyno my car after the cam swap my tuner could not get the car to take any more fuel. He added 60 percent more and the car didnt react at all. It ended up being the MAF sensor had gone bad.
Old Jan 2, 2011 | 09:12 AM
vettenuts's Avatar
Start with the intake centerline method. Then check valve events. Also, on the 0.006" measurement, I prefer to use the 0.050 measurement as a check because the 0.006" is right off the base circle and hard to achieve accurately.
Old Jan 2, 2011 | 10:31 AM
d2camaro's Avatar
On the cam card the only thing @.050 is duration. Cam card only has valve timing a .006. How do I find measurements @ .050?
Old Jan 2, 2011 | 10:37 AM
d2camaro's Avatar
Well we tried swaping my mass air for another and same thing happened. I have checked for vac leaks and have found none.So im at a loss.So should i advance the cam 6 Degrees to get it in spec with the cam card? Would that have somthing to do with the problem?
Old Jan 2, 2011 | 11:53 AM
technicalninja's Avatar
Post you cam "card" please'. Normally they will have timing istructions at .050 or intake centerline noted. Don't think I've seen a card that demands timing at .006. The other posters are correct. .006 is not usually accurate, especially if hydraulic lifters are being used.
On a symetric lobed cam you can estimate intake centerline if you have both an opening and a closing measurement but most of the cams I see for these cars have asymentric lobes and this method may not work (or will be far more difficult).
Every cam dial in card I have seen it the past 10 years includes an intake centerline reading (intake at higest lift).
Another problem is if you are using hydraulic lifters there is NO real way besides intake centerline to degree the cam. See Tony Mamo's (AFR guru) take on this in this thread https://ls1tech.com/forums/generatio...ay-method.html
A couple of thousands lifter compression would have that much effect on timing at .006.
Along with checking for rich mixture and retarded ingniton timing I would also verify I did not have too much exhaust restriction. I'd do a "back pressure" test. take an O2 sensor out, replace with a plug that has a port to hook up a low pressure fuel/vacuum gauge. Either have a long peice of steel tubing from this plug before you get to rubber hose to gauge or use a hi temp silicone hose and do this test quickly. You can make this plug out of an 02 sensor bung plug. Be easier that checking cam timing. Anything over 1 PSI is restrictive. If you have over 3 PSI it can also cause cherry red manifolds and power would not gain as quickly (or at all) past the restrictive flow point.
Old Jan 2, 2011 | 12:51 PM
d2camaro's Avatar
this is the cam card
Old Jan 2, 2011 | 12:55 PM
d2camaro's Avatar
this is what i got when dot to dot retarded 6 advanced 6
Old Jan 2, 2011 | 03:57 PM
"these specs are for cam installed at 110 degrees intake centerline".
You set intake centerline at 110 degrees and then "check" it at .006 as well. I wouldn't worry too much regarding the readings being a bit off at .006
Intake centerline is a BUNCH easier to get right and maybe the only "spec" you can really determine when using hydraulic lifters as no amount of bleed down will change the point of highest lift. The point of highest lift should be real close to 110 on your degree wheel. Adjust to this point and all should be well.
Old Jan 2, 2011 | 04:17 PM
garygnu's Avatar
your lsa is 112*,your intake center line is 110*.the cam has 2*advance ground in to it.it should be installed dot to dot.if you have to advance or retard it ,its the the wrong cam.get a EPS cam.pay for techninja gas money and he will help you out.who let the NASA engineer in?
Old Jan 2, 2011 | 06:59 PM
d2camaro's Avatar
Well I installed it dot to dot and the measurements dident match so i advanced it 6* and it was almost identical to the cam card. So what does this mean cam is wrong or its right?
Old Jan 2, 2011 | 07:05 PM
PM sent with contact #. Give me a call. Might be quicker.
Old Jan 3, 2011 | 05:16 AM
vettenuts's Avatar
Since this is a multiple key crank pulley, do you have a photo of it currently installed?
Old Jan 3, 2011 | 02:51 PM
got milk??'s Avatar
Answer his question he will get you fixed up!
