Is this stuff normal before a tune?
Old Feb 8, 2004 | 08:53 PM
chetyg's Avatar
Default Is this stuff normal before a tune?
Hi guys I just put stg2 ls6 style patriot heads on my car with the tsp231/237 cam and longtubes. It will seem like its missing some of the times is that cause of the misfire code the computer is setting? i know the surging is normal but sorta worried about the occational miss. I am fixing to start tuning as soon as i finish the exhaust tommorow thanks guys. chet
Old Feb 8, 2004 | 09:01 PM
98SS Blackattack's Avatar
I would check your plug wires very closely.
Old Feb 8, 2004 | 09:05 PM
chetyg's Avatar
thats what im figuring i just got it running and took it for a spin but cant see i will check all the plug wires tommorow
Old Feb 9, 2004 | 06:00 AM
racrx's Avatar
cracked plug, bad wire, possible vacume leak, just look around, and pull every plug and wire, the answer is there. racrx
Old Feb 9, 2004 | 06:49 AM
Steve98Z's Avatar
Check all of the above, check the and make sure all the rockers are tight, I once knew a guy that had a dead miss and drove it 3 hours straight with the rocker arm flapping around not even on the touching the valve
Old Feb 9, 2004 | 02:20 PM
chetyg's Avatar
well i found a loose spark plug wire but now the car wont start at all back to the ole drawing board
Old Feb 9, 2004 | 03:08 PM
samz28's Avatar
after i had my cam put in it was triggering a ton of misfires at low rpm, with efilive. It would even throw SES lights at stop lights. Had to have it tuned (and KR desensitized) to fix that. You have to understand these large overlapping cams at low rpm's and the "lope" is gonna cause the crank wheel speedy to vary, which is how the ls1 apparently determines a misfire. If it was misfiring at ALL rpm's that would be one thing, but if you just pay attention to low rpm idle misfire you might drive yourself crazy while the engine is making its lope sound.
Old Feb 9, 2004 | 03:12 PM
chetyg's Avatar
do you think the KR or something in the computer is causing it not to start cause i have looked at grounds/plugs/wires/vaccum leaks and everything and it still wont start. It is getting fuel and it is getting spark it will act like its about to start then wont. Im stumped as of right now. Will running open headers for a few hours burn up the o2 sensors and cause the motor to have fuel puddling and not start? the odd thing about it is that it ran fine last nite and drove it around and it did fine except the misfires and i found a loose pluge wire on that
Old Feb 9, 2004 | 03:21 PM
samz28's Avatar
o2 sensors are really hard to burn up man. The car doesn't start in closed-loop mode. It waits a few seconds IIRC when watching my EFILIVE it seemed like even on a warm start it would wait a few before jumping to closed loop mode. If the o2 sensors were dead the ecm would run rich you got gas pouring out the headers?
check your bat voltage make sure its not drained and try part-throttle starting it. Nothing like WOT that didn't work for me when i had cold start issues, seems the gm ecm does something different if you wot start the car.
Find a buddy with a tech2/autotap/efilive to see if theres an ecm issue.
On most ecu's there's a "start" procedure, which then hands itself over to the running (warmup) then switches to closed loop once it reads a strong signal/ECT temp.
I've done some stupid things to bosch o2 sensors like blow hg's on various cars and wash them, or run grossly oversized injectors without a tune, hell even one car ran leaded fuel for a tank and it didn't KILL the o2 sensor. May not be as good as new, but they are tough buggers. Think about all the moisture they must endure over the years..
Old Feb 9, 2004 | 03:28 PM
chetyg's Avatar
well i checked the battery voltage its fine and no gas coming out of the headers all grounds are connected all vacums are connected and everything is pluged up. so i am guessing it HAS to be something going on in the ecm right?
Old Feb 9, 2004 | 03:46 PM
samz28's Avatar
you got spark and fuel? What did ya do to make the car run poorly to not at all?
Old Feb 9, 2004 | 03:50 PM
chetyg's Avatar
thats the odd thing didnt do anything. it was running last nite just a misfire here and there checked it out today and pushed the plug wires and #2 wasnt all the way on and then i got in and started it it started up and when i gave it gas it didnt respond and i continued to try to give it a little gas and it still wouldnt respond to the throttle but it was running then it went dead and wont start now
Old Feb 9, 2004 | 03:54 PM
chetyg's Avatar
im really thinking maybe a rocker arm is loose or something in the ecm
Old Feb 9, 2004 | 04:14 PM
samz28's Avatar
where ya live? maybe a fellow ls1'er can locally come by and efilive/autotap your ecm to see whats going on?
I'm in atlanta, i'd do it if you were nearby, and im sure some other nice folks would help ya out unless you live in alaska or something lol.
Ask around the local forums. I bet theres some nice folk, there are some cool guys in atlanta.
Old Feb 9, 2004 | 04:44 PM
Y2KSS's Avatar
Pull a plug out and see if it is gas fouled. My car fouled out a set of plugs very quickly when I installed this same setup. Mine ran extremely rich until I tuned it and changed the plugs and now everything is good.
Old Feb 9, 2004 | 09:19 PM
chetyg's Avatar
im gonna check the plugs tommorow im thinking they are fouled cause of the way the car is acting. at least i am praying that is the problem lol
Old Feb 10, 2004 | 01:05 PM
chetyg's Avatar
the plugs are black and have gas all over them they are fouled im gonna change em out today thanks for all yalls help guys
