What lifter trays?
Old Jan 4, 2011 | 08:35 PM
00ss6speeder's Avatar
Default What lifter trays?
Rebuilding my ls1 with H/C/I using ls7 lifters, whats the beast trays to use?
Old Jan 4, 2011 | 08:39 PM
Darkman's Avatar
LS2 trays. Thunder Racing, among others, have them.
Old Jan 4, 2011 | 08:45 PM
Do I have to do any modifying to run them?
Old Jan 4, 2011 | 08:48 PM
supersick99z's Avatar
When I did my h/c and lifters and all I didn't get new lifter trays. Why spend the money they are not a moving part? Shop told me the same thing and I had 110K miles...
Old Jan 4, 2011 | 08:49 PM
Darkman's Avatar
Nope.
Old Jan 4, 2011 | 10:22 PM
NVR_SPDS's Avatar
Just bolt the LS2s in, and go. They replaced the LS1 trays.
Its not a moving part, but they do wear. Even though it may not be completely necesary to replace them, IMHO it would be a good idea, especially since they are pretty cheap.
Old Jan 4, 2011 | 10:25 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I wish I would have replaced mine when I did the H/C swap on my HOSS. Its almost too cheap not to do it.
Old Jan 4, 2011 | 10:26 PM
BlueBird346's Avatar
At $7 a peice, why not?
Old Jan 4, 2011 | 10:27 PM
wickedbluess's Avatar
ls2 tray for sure. super cheap
Old Jan 4, 2011 | 10:40 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
plus if you ever swap cams again, they will actually hold onto a lifter if you spin the cam over.
Old Jan 4, 2011 | 11:05 PM
SVThuh's Avatar
The main benefit of the LS2 trays over the LS1 trays is the fact that they promote better draining of oil back into the crankcase. The LS1 trays are notorious for filling up with oil and not allowing it to drain back efficiently.
Old Jan 5, 2011 | 06:19 AM
Too late now hope mine never screw up!
Old Jan 5, 2011 | 08:49 AM
Shockwave179's Avatar
+1
People also drill holes in them to assist with oil drainback.
Old Jan 5, 2011 | 08:58 AM
KCS's Avatar
KCS
Moderator
It's good to replace them because they are the one thing keeping the lifter from turning perpendicular to the lobe...and they're plastic.
Old Jan 5, 2011 | 09:19 AM
Jon@Texas-Speed's Avatar
Not a bad idea to replace them. I would go with LS2 trays. They are $30 or so for all four of them. We have them on the shelf if you need a set.
Jon
Old Jan 5, 2011 | 12:00 PM
sjsingle1's Avatar
so where exactly do ya drill the holes in the trays?
Old Jan 5, 2011 | 04:51 PM
joecar's Avatar
It's not necessary to drill holes, oil just simply overflows over the top.
Old Jan 5, 2011 | 04:58 PM
bmf5150's Avatar
Do dealers have them for a good price?
Old Jan 5, 2011 | 11:52 PM
joecar's Avatar
Yes they are utterly cheap, about $7 each.
Old Jan 6, 2011 | 03:58 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Or TSP can overnight them to you for what a dealer would charge.
