Camaro SS LS1 Engine Overhaul
My car is showroom floor stock, the basics are 5.7 ls1, 6 speed transmission, 10 Bolt posi traction, 3.42 gear ratio. Traction control delete.
Any way the cam I purchased is: Comp 54-428-11
This is the start of my parts collection, Im going to take the time to make sure the next parts I buy cooperate with eachother.
part #: 54-428-11 04/16/2010
grind number: Ls1 xr281hr-12
------------------intake------exhaust
valve adjustment hyd---------hyd
gross valve lift .571----------.573
duration @
.006 tappet lift 281----------283
valve timing-----open-----------------close
@ .006----int:---31--------btdc-----71---abdc
-------------exh:--76--------bbdc-----28---atdc
These specs are for cam installed
@ 110.0 Intake Center Line
-------------------Intake-------exhaust
Duration @ .050----228---------230
Lobe Lift------------.3360-------.3370
Lobe Seperation-----112.0
I have no comments on your cam other than most guys establish what heads/intake etc before buying a cam. In my past builds with BBC's, cam is one of the last things you purchase.
- Valve Train matched to Camshaft Above
- Fast Intake Manifold with 92 MM Throttle Body
- SLP Engine Damper
- Different Pistons
- Bigger Oil Pan
- Aftermarket Cylinder Heads Ported & Polished to Match Headers
- Hooker Super Competition Headers 1 7/8" Primaries
- 3" Hooker Headers 16723-1HKR - Hooker Y-Pipes
- High Flow Catalatic Converters
- MSD Coil Packs
- Optima Battery
2. FAST is always good.
3. ASP or ATI.
4. why? and if you are gonna tear down the block why not just buy a bigger motor? it'll be about the same price.
5. why? you don't need it.
6. what cylinder heads?
7. if you are stock cubes and using that little cam all you need is 1 3/4"
8. hooker sucks.
9. you do know that there are ways around cats right? and its cheaper. just saying.
10. don't need 'em.
11. what's wrong with the battery you have now? it's probably lighter.
1 3/4" headers, FAST, heads, cat back, ASP pulley, injectors, dyno tune, clutch, master cylinder, lca's, phb, sways, shocks springs, rear end, drive shaft. there is plenty that is recommended but not absolutely required.
i still don't know what your goal is.
http://www.youtube.com/watch?v=7MwELq2zSxU
