head swap problem HELP!
Old Jan 10, 2011 | 11:11 AM
slt200mph's Avatar
As was just posted if you have broken the block no need to pull the pan...you now have junk under the hood...pull the engine ... check you local salvage yard and find another engine.
Old Jan 10, 2011 | 11:49 AM
Darkman's Avatar
https://ls1tech.com/forums/generatio...lock-hole.html
https://ls1tech.com/forums/generatio...il-galley.html
Old Jan 10, 2011 | 08:48 PM
Jake99's Avatar
Well my junk is running again, I had it far enuf togther i figered id just run it and see what happends, looking at another block it looks like it poped the hole straight into the crank case so it wont hurt anything as long as whatever broke off doesnt cause a problem inside the engine. Had it idleing for 5 min and heard no knocks, no water/oil leaks, and no water in the oil.. yet. The worst that could happen is me having to get another engine anyways so guess time will tell.
Old Jan 10, 2011 | 08:53 PM
Darkman's Avatar
https://ls1tech.com/forums/generatio...torqueing.html
Old Jan 10, 2011 | 08:59 PM
raven154's Avatar
You may want to change the oil ASAP. See if the piece doesn't come out in the oil change if indeed you did pop a piece out.
Old Jan 10, 2011 | 09:04 PM
Classicrules's Avatar
The problem was caused by residual oil in the bottom of the tapped hole. When you started torqing the bolt, the bolt acted the same as a hydraulic piston because you were going against a "blind hole" with oil in it; this process is know as 'forced hydraulics' and will take path of least resistance; the thin wall of the casting block! The block may be scrap now, as this could have very well gone into a water jacket.
Classicrules
Old Jan 31, 2011 | 06:12 PM
Jake99's Avatar
Too any of those who watched this thread I went ahead and torqued the heads down and ran it like nothing happend, changed the oil and nothing came out.. got maybe 200 miles on and lots of wot pulls and no sign of anything wrong yet. So if this does happen to anyone else its posible you could be fine to run it.. I may have just lucked out but so far so good..
Old Jan 31, 2011 | 07:32 PM
ZexGX's Avatar
I think you just lucked out...
Old Jan 31, 2011 | 07:37 PM
Darkman's Avatar
Thanks for the update.
Old Jan 31, 2011 | 08:13 PM
Whiteaw57's Avatar
one lucky son of a gun........
Old Jan 31, 2011 | 08:46 PM
LS1MCSS's Avatar
Time for him to buy lottery numbers.
Old Jan 31, 2011 | 08:55 PM
  #32
Jake99's Avatar
lol i just hope it stays that way.
Old Jan 31, 2011 | 09:56 PM
  #33
Whiteaw57's Avatar
the screen on the pickup tube shouldnt pick it up. Im not thrilled sitting here thinking about a having metal chunk in my own oil but youll be ok. also be sure that that bolt sealed up. since you poked a hole in it the bolt hole is probably poking into the water jacket. I had a SBC do it to me one time. Just something to be sure of
Old Mar 5, 2011 | 04:31 AM
  #34
bonethugluv's Avatar
I sent you a pm Jake, I had the exact thing just happen. Hoping i have the same luck as im putting it back together now.
Old Mar 19, 2011 | 11:28 AM
  #35
slt200mph's Avatar
Hay Jake how is the motor doing? .... just curious on your situation...hope it is running great.
Old Mar 21, 2011 | 10:18 PM
  #36
jarednut4ever's Avatar
I noticed jake hasn't been on here yet. I am friends with jake, A little update. He just came down here to our local dragstrip and raced this last Friday night. He had no problems and his truck ran a 11.5 @ 116.5 mph. All seem to be good. He will probably chime in.
