MTI T1 Cam
Old Feb 9, 2004 | 08:41 PM
smokemup's Avatar
Default MTI T1 Cam
Someone is selling a used MTI T1 cam (221/221 558/558 112) for a great price. I'm looking for opinions on this cam.
Presently the set up is. 2002 camaro stripped A4, 2.73 gears, and completely with stock exhaust (manifolds and all).
I just bought a FTRA and TSP lid (but do not have them yet). I will also be getting a ported TB, ASP pulley, around a 3000 rpm converter, shift kit, trans cooler, and drag radials. I'm looking for a 3.23 rear end, also considering a 3.42. I have not yet decided on the exhaust and for now it will remain stock (maybe a cut out). I plan to keep the stock heads on for a while, I'm considering the AFR's but waiting for dyno results.
The car is a daily driver and it must be able to pass an emissions sniff test on the rollers.
How much of a difference in power do the 224's make? What type of springs are recommended? Can I re-use the stock pushrods?
Old Feb 9, 2004 | 08:54 PM
SLowETz's Avatar
Great all 'round cam.... period.
Great power, great tq., easy on the valvetrain, sounds GUUUUDDDDD.
My old T1 went 416/405 with all the obligatory bolt on's through a 12 bolt/4:11's, and slicks. Who says baby cams don't make power? It's ALL in the combo/tune.
Old Feb 9, 2004 | 09:00 PM
smokemup's Avatar
How does that cam idle? I'm concerned with the tight lobe sep.
Mazzenger's Avatar
I have an 98 A4 with the T1 and a 3500 stall - 3.23 rearend - lid - muffler and headers and stock heads. It has great midrange power and torque. It has a good lope to as well. I recommend changing the springs at least. Plus you will definately need a tune. 224 will probably have better peak power.
Not sure if it passes emissions?
Old Feb 10, 2004 | 12:39 AM
RMB's Avatar
RMB
I had the cam in my old red SS at www.poorhams.com . I loved it .It was a very streetable cam with excellent manners yet strong power and performance. I got 408 hp on Thunders Dyno with 373 gears using Mac mids and cats. If you want a great all around cam you cant go wrong. The sound quality is there yet it wont scare people away...the mildness actually seemed to lure some of them in . I would give it a shot .
Old Feb 10, 2004 | 03:04 AM
jrp's Avatar
jrp
SN95 Director
i traded my tr230 for a T1, have no regrets. its a great cam. the 230 did lope a bit more though
Old Feb 10, 2004 | 08:21 AM
JoSeY's Avatar
Get the X1 from MTI....sounds lopey.....but mash the gas and off you go.....get good valve springs though....MTI sells a package deal...set me in the 10's EASILY w/that cam, and it doesn't sound like a monster cam....very stealthy....and Jayson can tune the shizznit out of that cam. Even w/my A4 I went 112 LS and never had a problem...
Cam specs are 230/227/ .591/.571 112 or 114 go w/the 112....cam sounds like you have a baby cam in the car. With worked over MTI heads, 4000 3disc vig, and around 3400lbs the car went 10's all day long. and that's w/out the N20
Old Feb 10, 2004 | 08:22 AM
JoSeY's Avatar
and this was with a stock 323 rear end!!!
Old Feb 10, 2004 | 08:53 AM
smokemup's Avatar
thanks for the replies. Of course I waited a bit too long and the cam may be sold. If it doesn't sell I'll buy it.
JoSeY... I don't think the X1 from MTI will pass emissions for me. Sounds like you have a killer set up.
Old Feb 10, 2004 | 09:06 AM
JoSeY's Avatar
no aftermarket cam will truly pass emmisions...u have to "Know" someone for ur inspection sticker......hell I haven't had cats, egr, anything on my car for yrs.....
JoSeY's Avatar
oh and thanks for the compliments
Old Feb 10, 2004 | 10:40 AM
greekss's Avatar
um it would pass smog if it were on a 114lsa...... thats y i got the b1 cam, cuz im in cali and emmision is a beotch.
Old Feb 11, 2004 | 05:15 AM
Spinmonster's Avatar
I passed in NY with the 112lsa
