best cam only/nitrous cam
AKA 93 mazda rx7, its a hybrid swap, but i will be able to use LS1 edit which will be great. Motor is a 98 ls1/t56 SPEC 3 clutch, ASP underdrive pully, coolant bypass, EGR eliminated, no cats, custom true duals w/ cut outs after headers, ported TB, custom cold air intake, dyno/street tuned with LS1 edit.Of course i want a cam that sounds mean, a lumpy idle isnt a big deal with me and the cams power cant exceed 6500 RPM as i will have a stock bottom end. Thunder racing is having a special that ends the 14th and i want to order something before then, so help me out! i guess i am limited to their selection http://www.thunderracing.com/index.c...yid=1114#T1159
For the record i did use the search function and went through numerous pages on the engine internals forum and no dice.
*cliff notes:
-sweet sound at idle/entire RPM range
-good with nitrous (100-150 shot wet)
-most importantly great power gains on stock ported heads
-weekend car, so daily driveability doesnt matter all that much
Let me hear some responses backed with actual numbers you, or someone you know put down! thanks to all that help me out
----for the non beleivers, go to www.hinsonsupercars.com
thanks
-james
should give me good power gains i hope, aside from springs and rods,, are Ti retainers needed? Anything else recommended? What kinda numbers could i expect with this setup? only a few more days till the special ends! thanks
-james
99-227/224-114 lsa
99-224/227-114 lsa
I really dont want to go with a new rocker setup, just springs, ret, and rods will be good enough for now. Im new to this cam stuff with V8's so bare with me. thanks for all your help so far. Hopefully one of the two cams listed above should do the trick.
-james
i've got the 230/224. you don't have to get aftermarket lifters or rockers for this cam. however, it does like to rev, quite a bit past 6500. my car peaks at 6500 and just flat lines till 7000 rpm's (havn't taken it any higher than that, but it probably could).
with any of the thunder cams i would suggest getting the crane duals with ti. retainers. those, pushrods, and gaskets is all you should need. oh, and a balancer bolt. good luck
looks like its the 224/227 114 Lsa for me! thanks again.
-james
black knight you seem really knowledgeable in this area, what do you think?? anyone else ? thanks.-james
Of course, with Nitrous, you may well find that your ideal setup will be spinning up higher. I don't know too much about n2o.
Really, some of this can get very complex. I only just barely have my toes in it, so to speak. Like I said, take your time and get some expert opinions. I think you have clear goals and I recommend you stick to them. Just make sure that before you make a decision that it's not just "roxor kewl" but will actually do what you want it to. (i.e. a maximum power cam that peaks under 6500 RPM that will handle nitrous and can sacrifice "daily drivability")
You usually want to subtract at least a degree for every 50 HP no?
I think you want the 224/227-114 lsa
