Old May 18, 2016, 06:15 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
How to drop engine from bottom with k-member
Old Nov 25, 2024 | 09:26 PM
Knowbetterbdia's Avatar
Default Engine out bottom
Originally Posted by King Nothing
like this and roll it out on the tires, just take off the front bumper so the shocks clear the body
Attachment 671200
Attachment 671201
Attachment 671202
You are one smart feller. If I ever do it again, this is the way I'll go, doing everything at once.
No more (monkey fn. pumpkin for me. )
Old Nov 25, 2024 | 09:47 PM
Default Remove engine with K-member.
I have a 2-post floor lift, and an engine hoist.
Question: Why wouldn't I be able to lift the whole with the body about a foot to get under it.
Put a floor jack under the K-frame, as well as a short trans jack to keep them mated. Then unbolt the subframe, and lower the engine.
Then raise the car enough to roll the entire front end out, while lowering the trans. jack, as needed.
Wheels on the trans jack would facilitate roll out.
Old Nov 26, 2024 | 05:38 AM
LS1Formulation's Avatar
I did similar, but without a lift. I had my car up on wheel cribs. However, my core support is cut, which makes getting the engine hoist in WAY easier. I dropped my old K-member but left the front suspension in place, bolted the new tubular K-member to my engine and set the engine and trans combo on a trans jack and Harbor Freight furniture dolly. Seemed like it would be unstable, but I tried rocking it and it was solid as can be. You need to be more than a foot in the air though.
