How much did you spend to Cam your LS1?
#41
I was a broke college student!!..lol..cam sat in my back seat for like 4months before i got everything else together...drove home on a friday tore down the car and installed the cam on saturday then drove back to school on sunday..lol
#43
you will get similar results with a set of cheap patriots as you will with doing porting on ls6 heads....and you wouldnt have to do the work twice..
depending on the size/duration/ramp rates of the cam those springs were used on previously, and if the owner warmed up the valvetrain before beating on it, you could be well past half the valvespring life.
I've had springs last 7k miles, and I've had them last 25k+ miles....
there is no telling when one will give out based on a guess from the previous owner
I would highly suggest you test them when you have your heads off to have the CNC work done to them, and make sure the springs are still within good specs...
and then test them every 5k miles
#45
Either way,
It's too damn much money by the time you add a dyno tune in there,
I may do an all aluminum motor/ Carb, set up in the future
just so I can have fun and not break the bank
#46
if you can find used cam and pushrods, which you can easily be run used after inspection, cut that cost in half.
#47
Restricted User
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
#49
on cam only you wont need a pump upgrade
and you *should* be fine on the stock injectors.. I cant remember which years had the lower injectors, but you need the Bigger LS1 injectors for sure to play it safe, and its never a bad idea to upgrade the injectors anyways
99% of NA 346 can use the FAST 36.6 Lb injectors and still have plenty of headroom
#51
#52
as for me.
Futral Cam 400
used PR had a dyno run on them(wrong size) iirc 80 bucks
ls6 oil pump 100~
patriot gold duals 220ish (bought them on sale)
ls7 lifters 110
ls2 trays 40ish
complete gasket kit with everything and then some 170ish
I got all lifters and gaskets together i just remember it being mid 200s
243 new castings 700 bucks sold springs/retainers and locks off these for 60 bucks
fluids a bit of money
and then..turning a heads/cam nitrous build into a turbo build mid build...
priceless lol
#53
#54
Yes. As the saying goes" Better safe than sorry.." An ls6 oil pump goes for what? a hundred bucks or so? A hundred dollars is better(see cheaper) than an engine rebuild.
as for me.
Futral Cam 400
ls6 oil pump 100~
ls7 lifters 110
ls2 trays 40ish
priceless lol
as for me.
Futral Cam 400
ls6 oil pump 100~
ls7 lifters 110
ls2 trays 40ish
priceless lol
better do a trunion upgrade
oh your using nitrous? better change your pistons out to something forged
make sure you change out you rod bolts too
wait patriot dual golds? no way. get the '11 treated PACs
IT NEVER ENDS
any ******* can buy and change parts, the guys that know what they doing spraying and tearing the motor down every other event know what needs to be done or not. brings me to the reuse head gaskets BS. there are people spraying 250shots on reused MLS gaskets, do you think a stock motor will push the gasket to 60% of what the nitrous motor will?
your changing your timing chain because your increasing the load on the chain from more aggressive cams and increased spring loads.
how does the timing chain compare to the oil pump?
the pump is a meh lets change it because im here just like the lifters.
the timing chain NEEDS to be upgraded to maintain a margin of safety as the GM engineers intended.
the LS6 pump is not an upgrade, its a maintenance replacement part.
im not saying not to replace the pump, but dont turn around and tell me i cheaped out because i ONLY spent 800 on a cam swap. i easily could have spent $350 and had 85% of what i have now.
specifically this goes to you soundengineer calling people retards and cheapskates because they didn't follow your idea of acceptable. funny this is all coming from a guy that put a $7000 motor in a $10000 car.
#55
ls1jorge if you just changing a lifter and are not really interested in a cam swap i retract my advice to go bigger. imo i would spend 50 bucks on new ls6 springs throw in the 405hp ls6 cam and keep your stock heads if you want a couple extra ponies just do a quick light port yourself. no tune needed and be done.
#58
That was when I thought the programe I wanted to go to school for started this semester, but it starts in sep.. so the car gets to stay! Gonna refresh the tranny and possibly cam it. Im possibly buying a used cam from a friend, 231/237 cam.
