How do you check bearing clearance the right way?
Luckily my work has top shelf mics and telescopic bore gauges, but I will double check with plastigauge.
I am using arp head bolts and whatever comes with the H beam rods, do they need torque cycled a few times or is less cycles better?
![Smile](https://ls1tech.com/forums/images/icons/icon7.gif)
![Angel](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_angel.gif)
the aforementioned is correct / make a list and check it thrice (3). If in doubt ask and verify readings to avoid issues.wishing you the best with this project build. Have a blessed day..
Jim
