AFR 205 or TFS 215 on 408
Old 01-26-2011, 09:11 PM
BrianSF-GA's Avatar
Ouch on the rear ... I am deathly afraid to put anything sticky on my 10-bolt until it's out in favor of a 9". That way I still have it when I de-mod and am ready to sell. Let the forum know how the stock 10-bolt holds up.
Old 01-26-2011, 09:19 PM
Evans752's Avatar
I would go with the Trick Flow 215's myself, I am saving up for a set of them right now for my car.
Old 01-27-2011, 05:54 AM
vettenuts's Avatar
The heads I have that Tony worked on have excellent intake flow but also have unbelievable exhaust flow. This may influence any cam decisions with regards to duration and if you go with the AFR's you may want to contact Tony and talk to him about cam choices.
Old 01-27-2011, 07:47 AM
BrianSF-GA's Avatar
"vettenuts" ... To satisfy my curiousity, do you have the flow #'s on your heads? I would like to compare them to my TFS CNC ported 215's.
Old 01-27-2011, 11:07 AM
david vericker's Avatar
Originally Posted by CrushtheQuarter
Thanks for all the input. I am not looking at any other head choices for now. Both of these heads are available for me to use.. The Trickflows are new never been installed and the AFR 205s have i think 1 or 2,000 miles on them. Forgot to mention this is for a naturally aspirated application. They are both works of art.
You say that both heads are available for you to use,meaning that a purchase is not necessary? Wow,if only you could bolt on both sets of heads and do some dyno pulls,that would tell the true story of which set of heads actually produces the most HP/TQ on a 408. I know it's a lot of work involved,but it would sure separate the bullshit form the facts.
As you must be aware of the two heads mentioned will not produce the maximum HP/TQ that a 408 is capable of.
Old 03-10-2011, 07:51 PM
justinj's Avatar
Here is some facts.. 408 with TFS 215s 505hp and 478tq on the texas giant in lubbock texas. pistons at -10. and heads miled to 61. With a 95 ported fast.
Quick Reply: AFR 205 or TFS 215 on 408
