ticking noise after cam
Old Jan 29, 2011 | 01:13 PM
xtreme1604's Avatar
Default ticking noise after cam
i put a cam in over the fall and it has a slight ticking noise. nothting real bad or loud just wondering if that is normal. i put in a MS3. stock heads.
any input will be helpful. thanks
Old Jan 29, 2011 | 01:22 PM
01ssreda4's Avatar
What pushrods did you use?
Old Jan 29, 2011 | 01:45 PM
xtreme1604's Avatar
tsp 7.400
Old Jan 29, 2011 | 01:54 PM
ez money's Avatar
mine makes a little valve train noise but it aint loud
Old Jan 29, 2011 | 02:15 PM
01ssreda4's Avatar
7.425s may be a bit quieter.
Old Jan 29, 2011 | 04:40 PM
xtreme1604's Avatar
longer ones would be quieter?
Old Jan 29, 2011 | 05:55 PM
01ssreda4's Avatar
They will add more preload, however I would ensure that one of the rockers isnt the reason for the noise.
Old Jan 30, 2011 | 01:03 PM
xtreme1604's Avatar
im sure all the rockers are tight. would there be any other problems with the rockers? to make that noise other than being loose?
Old Jan 30, 2011 | 01:20 PM
Dmaleck's Avatar
Could have a bad Lifter that is not pumping up, bearings in the actual rocker could be bad. How loud is it? My c5 has a ticking also, but I was told on the ls1's with a bigger cam the valvetrain gets noisy from the valves closing faster because of the lobe angle.
Old Jan 30, 2011 | 06:20 PM
01ssreda4's Avatar
^^^That was a lie. I have heard tons of camm'd LS1s that do not tick.
Old Jan 30, 2011 | 07:30 PM
KevinR's Avatar
I had a lifter take a dump right after my cam swap. Could be that, but it could also be pushrod length as well.
Old Jan 30, 2011 | 10:02 PM
BarneyMobile's Avatar
Depending on the cam lobe profile, some increase in valvetrain noise is normal but most of the time the excessive noise is from incorrect pushrod lenth.
Old Jan 30, 2011 | 10:48 PM
xtreme1604's Avatar
i have a ms3 with 7.400 pushrods. is that the wrong size? the noise really only seems to be comeing from the driver side heads. but i have been told that it is normal for a bigger cam to have a little ticking noise but it bugs me.
Old Jan 30, 2011 | 11:06 PM
Greekey's Avatar
Did you measure for pushrod length after the cam was put in?
Old Jan 30, 2011 | 11:15 PM
xtreme1604's Avatar
no i did not. i orderd the ms3 package from texas speed. and it had the 7.4 as the standard lengh so i went with that. how do you measure for pushrod length?
Old Jan 30, 2011 | 11:43 PM
Greekey's Avatar
Measuring for pushrod length is done with an adjustable pushrod. Speeding. Sells them. Do a search for measuring pushrod length and you will find it. Id give you a link but I am on my phone at the moment. I'll help you tomorrow.
Old Jan 30, 2011 | 11:44 PM
Greekey's Avatar
I meant speedinc.
