Lq4 rebuild questions.
Old Feb 7, 2011 | 02:01 PM
tylerdustin2008's Avatar
Default Lq4 rebuild questions.
Hello.
I am buying a completely tore down lq4 on Wednesday, and am needing a few questions answered.
Everything is included with the motor, but since the motor is tore down I think it would just be wise to rebuild it.
First question, is where can I find a rebuild kit decently priced?
Since this will be my first complete engine rebuild, does anyone have any links to where I can see a complete rebuild on this motor, or even LS1/LS2?
Also what some good material to use to rebuild the motor, such as a book, or a dvd.
Thanks allot.
Tyler
Old Feb 7, 2011 | 02:06 PM
NemeSS's Avatar
What yr lq4? A .030 overbore rebuild with replacement pistons is a good start
Old Feb 7, 2011 | 02:20 PM
The motor is a 2004.
The motor is actually really clean, main bearings look great, piston walls are very smooth.
Old Feb 7, 2011 | 02:30 PM
96lt4c4's Avatar
Is there a lip at the top of the bores? You may be able to run it like it is. Why was it pulled? How many miles?
Old Feb 7, 2011 | 02:32 PM
It was pulled because it had sat for a little while and a ring had stuck. Yes the lip is still there. 60k.
Old Feb 7, 2011 | 09:34 PM
96lt4c4's Avatar
If the walls are not scarred up you may be able to slightly hone it and re-ring it. If you are on a budget.
Old Feb 7, 2011 | 11:42 PM
If the walls are not scared up you may be able to slightly hone it and re-ring it. If you are on a budget.
They are not scarred at ALL.
So what are some recommend rebuild kits?
Edit: Didn't know the past tense of "scar" was spelled with two "r's".
Old Feb 8, 2011 | 03:50 AM
I'm sure its me, but I can not seem to find a single damn thread, or video where someone has tore down a motor. And then rebuilt it, I am a visual learner.
Old Feb 8, 2011 | 07:35 AM
96lt4c4's Avatar
I dont have much experience with building LS motors yet. But, I have built plenty of small block chevys. The last kit I bought was form CNC Motorsports. I am sure any of the vendors on this site can help you out.
I think you have to use the LS1 crank.
Old Feb 8, 2011 | 12:16 PM
I am am going to use the stock Lq4 crank, because it looks fairly good.
Plus I've did a rough price mock up last night, I am looking at $6,000.
I am buying the motor tomorrow, so I am going to give it a good look over. And then start ordering parts.
But see my main problem is not being able to find **** in a kit.
But to double check, will all of these bearings work?
Main Bearings
Rod bearings
Cam Bearings
Also whats a good gasket kit, I do not want cheap gaskets.
Old Feb 8, 2011 | 12:35 PM
ls1leadfoot's Avatar
i got a lq4 outta a junk yard for a deal man...truck was a 2001 and had sat for 2 years...took it to a shop to do rebuild on the bottom end and turned out great....only thing i wish i had done was go with flat top pistons instead of the factory -2cc disc...so as another member said....why not 408ci
gaskets depend on the pistons too...if you deck your heads you will need a diff. thickness/better gasket with flat top pistons...but if you leave them in your comp. will be around 9:5:1 i think....also cnc motorsports has good prices too!!!
glw build
Old Feb 8, 2011 | 01:34 PM
glw build
I'm leaving the motor the way it is. Perfect motor for a turbo, so about 2 months after I finish my build I am going to aim for 8psi, and leave it at that goal of 550 to the rear wheels.
Old Feb 8, 2011 | 02:29 PM
that sounds like a good plan LOL
good luck bro
Old Feb 8, 2011 | 04:03 PM
good luck bro
Thanks.
Are those bearings above correct and suitable for my purpose?
Old Feb 8, 2011 | 05:12 PM
96lt4c4's Avatar
Call Texas Speed and Performance. They have GM gasket kits.
Old Feb 8, 2011 | 07:14 PM
NemeSS's Avatar
If u plan on turbo. Just get the 7 layer mls gm ls9 gaskets. Designed for forced induction by the general. Less than or round 100$ shipped from gmpartsdirect or other gm sources
Old Feb 8, 2011 | 07:24 PM
Gmpartsdirect is confusing. You have to know parts numbers, and the search auction they do have shows about a quarter of the parts they should.
Old Feb 8, 2011 | 07:27 PM
NemeSS's Avatar
Or just get from SDPC or TSP in Texas they are both sponsors on here. And it's a popular gasket for forced induction builds
Old Feb 9, 2011 | 03:16 AM
I think I will give them a call and get a price quote.
Old Feb 10, 2011 | 09:29 PM
So does anyone have any links to videos or walk-throughs on a ls engine tear down and build up?
