400 rwhp?
Old Feb 13, 2004 | 12:24 PM
x phantom x's Avatar
STF veteran / 10 second club
Originally Posted by 4thGENRETARD
12.75@ 116mph. Do you believe that! raceweight weight 3320
You sure this is an SAE corrected 400rwhp? I'm not calling BS, but as others had said, a similar setup to that on an M6 would be around 360-370rwhp, max .... a4's are always significantly lower than that.
Gotta graph for us?
Old Feb 13, 2004 | 02:19 PM
Roger White's Avatar
I did 389 rwhp locked with my cam-only set-up. It might have made 395 if I ever really tried to dyno higher but dyno's are only a tool.
Old Feb 13, 2004 | 02:54 PM
Mike Hoffpauir's Avatar
Originally Posted by Eric L
Didn't someone with a A4 get 402 rwhp with the futral f4 cam?
Eric
We made 400 rwhp with my car. This is an a4 with 4.10's and the futral 226 cam. The converter was locked. We made 366 unlocked.
Old Feb 13, 2004 | 03:23 PM
4thGENRETARD's Avatar
It's all in the package and some really good tuning.
LS6 intake, ASP, LT's, dual cutouts, meziere, carbon DS, ported TB, maf ends, fipk, adj fuel reg, 1998 injectors, 2001 fuel pump,SLP 1.85 rockers, SF TCI Trans, and few other things + a lot of weight reduction.
