V3 cam
Old Feb 21, 2011 | 05:54 PM
BlackBirdRyder02's Avatar
Default V3 cam
Can you drive a v3 cam with a stock stall my friend said I could for right now until I get a real stall. Cause my motor is out
Old Feb 21, 2011 | 06:32 PM
Anybodyyyy
Old Feb 21, 2011 | 06:50 PM
I need to know asap
Old Feb 21, 2011 | 06:56 PM
RJB01camaross's Avatar
Need more info then that. Which V3 cam are you talking about? Cam specs? I dont know of many V3 cams that would be stock stall friendly unless its the Cheater V3 by Thunder or something like that
Old Feb 21, 2011 | 07:49 PM
The texas speed v3 cam
Old Feb 21, 2011 | 08:13 PM
reeperz28's Avatar
itll be fine it just when you take off its gonna seemlike barely any power from a stop/idle but its fine but i reccomend anything from 3000 too 4400 stall with your cam
Old Feb 22, 2011 | 12:21 AM
Ok cool at least that will give me somr time to get the stall. Cause im on a low low budge
Old Feb 22, 2011 | 02:02 AM
what is the stock stall size any way?
Old Feb 22, 2011 | 03:19 AM
anyyy
Old Feb 22, 2011 | 06:08 AM
garygnu's Avatar
stock stall is about 1800 rpm.you will need a tune.are you installing the needed springs and push rods?it is alot easier to install a converter with the engine and tranny out.
Old Feb 22, 2011 | 06:16 AM
00MaroonZ28's Avatar
You should go ahead and get another TC with a higher stall right now. I picked up a TCI 3500 for about 500 new and it worked fine with my old cam, which is similar to the V3.
Old Feb 22, 2011 | 09:35 AM
Jon@Texas-Speed's Avatar
We typically don't recommend putting that much cam in an auto without a converter. Driveability will be bad with out one. It will try and die when you put it in gear and will be pushing through the brakes at idle. I would save up some extra cash and put one in while you are doing the other mods. Also, I didn't see where you said above, but you MUST install springs and pushrods with that cam!
Jon
Old Feb 22, 2011 | 12:47 PM
oh yea i have push rods and springs imma just get the cirlcle d stall for 396 for right now
Old Feb 22, 2011 | 04:08 PM
i think imma do that too
