Cam and gear
Old Feb 21, 2011 | 08:35 PM
cory32690's Avatar
Default Cam and gear
150k ls1 longtubes,ory,lid,85mm maf free mods ls6 intake
just ordered yank 4k stall going to get frost tune
what's a good cam and gear set up for me
Old Feb 22, 2011 | 08:16 AM
1BAD06MCSS's Avatar
MS4, 4:30's LOL!!!!
Old Feb 22, 2011 | 08:39 AM
cory32690's Avatar
Ok maybe I should have said a good cam and gear for a daily driver and take to the track twice a week in the summer
k
Old Feb 22, 2011 | 08:56 AM
1BAD06MCSS's Avatar
get ahold of Pat G or Geoff from EPS and have them spec you one. I would do a minimum of 3:73's to utilize any cam. With your stall, you have plenty of room to play with a large cam.
Old Feb 22, 2011 | 08:57 AM
bayer-z28's Avatar
^ Ditto.. PatG.
Old Feb 22, 2011 | 09:00 AM
juicy's Avatar
I wouldn't go anymore than 3.73s with an auto if you are gonna do the 1/4 and be a DD. And a custom cam is the way to go.
Old Feb 22, 2011 | 10:38 AM
cory32690's Avatar
Ok thanks for info I guess I'll get a custom cam made then when that comes
any other bolt ons I can do while I'm doing the stall swap I the next few weeks
Old Feb 22, 2011 | 06:10 PM
1BAD06MCSS's Avatar
what are your power goals? budget? It all depends upon how much you want to play....
Old Feb 22, 2011 | 08:37 PM
cory32690's Avatar
The cam won come for a few months I really want to see how fast the car can go on stall
i'm just think like a $500
Old Feb 23, 2011 | 08:48 AM
1BAD06MCSS's Avatar
If you plan on doing just a cam for $500, you must be smoking crack.... It will cost you way more than that to properly install/tune a cam. The cam alone will be $399. Tuning will run you anywhere from 200-500, depending upon who does it. The "hidden costs" of doing a cam like springs, pushrods, timing chain, oil, coolant, new oil pump will run you at least another $500 for brand new things. To do a cam in any f-body, you are looking at 13-1400 dollars with new parts. That does not even include labor if you DIY. Most reasonable mechanics will charge around $60/hour. This is a 6-8 hour job.
Old Feb 24, 2011 | 07:21 AM
JustAFooL's Avatar
I'm sure you already are doing this, but just in case your not, definately throw in a trans cooler when you put your stall in and a transgo hd-2 shift kit will definately help with the "soft" shifts you'll get after the stall.
