View Poll Results: WHAT CAM WOULD YOU PICK
TSP MS3 237/242 603/609
16
21.05%
VR VRX5 236/238 603/609
4
5.26%
TSP 233/239 595/603
7
9.21%
EPS 230/238
30
39.47%
THUNDER RACING RAPTOR 236/242 616/615
11
14.47%
LG G5X4
8
10.53%
Voters: 76. You may not vote on this poll
What cam WOULD U PICK
Old Feb 26, 2011 | 08:25 PM
  #41
BOBS99SS's Avatar
Captain Double Post
Do yourself a favor and call a sponser,if its a street car I see no need to throw a huge cam in there,and I run a ms4 in my car (no fly cutting on stock heads) if your gonna go big on the cam just make sure ya set it up right,
Old Feb 26, 2011 | 09:59 PM
  #42
dkbmxer002's Avatar
i have a 347ci daily driver with a bigger cam than all of these.. go big or go home. but talk to a shop to get something specific to your setup so you get the most out of your cam..
Old Feb 26, 2011 | 10:22 PM
  #43
garygnu's Avatar
you must consider dynamic pressure with combination needs,gears,stall ,weight,etc.get a custom cam.a shelf cam is hit or miss.a custom cam is taking in every thing and balancing it out .
Old Feb 26, 2011 | 10:36 PM
  #44
Detoxx03's Avatar
Don't need a big cam to get the job done
Old Feb 27, 2011 | 09:01 PM
  #45
mikemunoz's Avatar
anyone else
Old Feb 27, 2011 | 11:41 PM
  #46
ls1 1990 VN's Avatar
Originally Posted by mikemunoz
anyone else
So what is it you have: p&p tb, Bbk intake, or fast 78tb and fast 78 intake? either way you are looking for a big cam, are you not going to need air?
Sort out your TB & intake first
Old Mar 22, 2011 | 09:13 PM
  #47
mikemunoz's Avatar
bump...
Old Mar 22, 2011 | 11:31 PM
  #48
z99ls1's Avatar
Restricted User
Originally Posted by SWEET98SS
I vote Streetsweeper, it puts a grin on my face everytime I start and floor it, its amazing
Your times seem slow for your mods
Old Mar 23, 2011 | 09:52 AM
  #49
s346k's Avatar
I'd look at the g5x3. A friend of mine went 11.60s at 116 with that cam, headers, 4k stall and dumped duals. Stock tb, ls6 intake, stock pulley, wheels, susp, everything else. Went 10.70s at 129 on a 150 shot. Very simple setup with a lot of stock parts that ran hard. It's all in the tune.
Old Mar 23, 2011 | 03:25 PM
  #50
MYSTIC-1SC's Avatar
The 233/239 or the MS3 are great choices from TSP. Either one of those will get you great results.
Old Mar 23, 2011 | 09:13 PM
  #51
SWEET98SS's Avatar
z99ls1, my car has stock gearing which killed my times. My 60 foot was horribly. I am going to get. 12 bolt with 410's that should help alot
Old Mar 24, 2011 | 07:25 PM
  #52
mattster03's Avatar
the mystery specs on the EPS 230/238 are 0.600"/0.604" 112+2LSA... just ordered one for my car, so that'd be my choice
Old Mar 24, 2011 | 07:42 PM
  #53
Johnnystock's Avatar
do i need to flycut with that cam ^^^^^, plus can i re-use my stock head bolts
NO you cant reuse your stock head bolts!!!!!! Get some ARP bolts, you can reuse them 4-5 times..Good investment!
I'd go with the smaller cam too since your stall is not perfectly matched for top a end screamer cam.
I voted for the smallest cam, the EPS 230/238.
Old Mar 24, 2011 | 07:48 PM
  #54
davidws6's Avatar
+1 , depends on when you want the power band.
The 233/239 on a stock cube engine, the power band will prolly be way up top !
