Information regarding the Thunder Racing T-ReX camshaft
Jason,
Thanks for the info. Another question. How do you and Geoff feel about this cam in a big bore and how about a stroker/bored LSx motor? Seems the specs of this cam are much larger than the cams we typically see for those motors as well
Todd
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Todd
Shorty Director
Originally Posted by Jason99T/A
The cam is set to idle at 1000 rpms. With the tuning Geoff has done, it has not stalled once.
Jason
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
Jason
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Jason awsome numbers, do you think a 3000 stall with 4.10's would work ok for a while? I an looking into a 4200 but need a little while that. When do you think you will run it at NPR?
STF veteran / 10 second club
Jason,
I still have my initial ls1edit tune from when I had my TR220 114 installed.
The idle is set at around 900-950ish .... I have a 224 112 now which seems to run good on that tune also ...
How do you think this cam would run on a tune like that? I have to drive around 100 miles (through NY city) to get to the shop to have it re-dynotuned. You think it would be a problem with that tune, or would it be okay?
#36
Originally Posted by GrannySShifting
It would definitely want a tune different than a 220 114 LSA cam
#40
Adkoonerstrator
Originally Posted by BoneSS
Any daily driver stock cubed a4 guys going to try this cam?
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
