advance my comp cam or not
Serial # X 9309 Spec Card# 026347
Part # 54-000-11 CAMSHAFT, LS1 CHEVY LS1/GEN III '97-UP
Core C54-11C CAMSHAFT BLANK, LS1 1997 UP 5.7 CORVETTE
Grind # LS1 3714R /3716R HR114.0
DURATION @ .050 INTAKE 222 ROCKER ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 226 INTAKE 1.70
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3330 EXHAUST 1.70
VALVE LIFT INTAKE .566 LOBE LIFT EXHAUST .3350
VALVE LIFT EXHAUST .569 LOBE SEPARATION 114.0
DURATION .006 INTAKE C/L 114.0
TAPPET LIFT INTAKE 275 CAM ADVANCE 0
TAPPET LIFT EXHAUST 279 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 3- JOURNAL DIAMETER STD 2.165
VALVE OPEN EXHAUST 47 RECOMMENDED VALVE SPRINGS
VALVE CLOSED INTAKE 45 DEPARTMENT R
VALVE CLOSED EXHAUST 1- SPC INSTR FOR CUSTOMER
Unfortunatley, that does open your exhaust valve quite a bit earlier as well, but is the bext compromise for you you wish to use the car. Another option would be a custom grind, like shown below.
222/226 114+0 222/226 114+4 218/226 109+2 IVO -3 1 2 IVC 45 41 36 EVO 47 51 44 EVC -1 3 2
Not only do you get more useable power like this, you also limit the RPM required to use it, paramount to keeping a 4L60e allive (although you didn't mention what trans you have).
