LQ4 Cam advice. Cam to be bought this week.
Setup is...
0mi Lq4
FAST 102mm
47lb injectors
PAcesetter LTS\
TSP X
4200 stall
builts 4L60e
I have the trucks heads on the lq4 now and my 241s are still good on my ls1.
Other misc parts...
All i need now is a cam and springs... im already set on a set of Comp 926's...
As far as cam goes i dont wanna go crazy big like before... aka Polluter and a custom grind that was 239/245 615/618 110.
I was looking at the VRX5 from Veng and they said it would be pretty good in my set up, also called TSP and they recommended the MS3 which ive heard good things about.
I gotta find that sweet spot in the cam as now I have lower compression yet i still rock the 4200 stall...
Leaning to the VRX5 atm.
Thanks for any input
Question 2: Why not sell/trade your 317 truck heads in favor of some 243/799 heads that flow just as well and have smaller 64cc chambers?
Question 3: What are you doing with this car? Doesn't appear to be a daily driver, but what is your mix of street/strip driving?
Question 4: Do you realize all of the cams you've mentioned differ only slightly from one another?
24x/24x 112
239/245 110
236/238 113
237/242 112
If you really wish to try a smaller cam to work with less compression, 2-3 degrees isn't really worth mentioning. Truth is, everything you've had or suggested would be best at 11:1 or more compression.
As far as getting a different set of heads I'm kinda on time and budget constraint but if I get lucky ill grab some 243s. Been looking no dice.
Also yes this car is much my preferred dd. Has been since 07. All these motor problems just came about after moving to az last year but oh well.
been using the larger cams just because I love the sound and have always made pretty good power. 412/405 on the last setup. But I'll leave my specs to the guys at vengeance. If its smaller due to the scr for optimum power so be it.
Really wish I could find some heads at rock bottom price in the next few days though
