Biggest baddest head I can get
Old Mar 2, 2011 | 07:42 PM
99slobird's Avatar
Default Biggest baddest head I can get
Ive got my ported 241s sold. I'm thinking about getting the prc 227s for my forged 383 a4 car with 102/102 setup and a 200 wet shot. What is the head that I will get the most out of with just a head swap? I also have a ms3 cam and am looking for max effort heads? Please steer me in the right direction thanks
Old Mar 2, 2011 | 08:10 PM
CNTLSE 1's Avatar
I went with the 227's for my MS4 setup. Dont have them installed just yet. working on it and gathering more parts
Old Mar 2, 2011 | 08:11 PM
RARON455's Avatar
I would say if your budget allows, a set of worked up AFRs wold get it done.
Old Mar 2, 2011 | 08:13 PM
BBC632Camaro's Avatar
Afr's or Lingenfelters in my book
Old Mar 2, 2011 | 08:16 PM
Always2Slow's Avatar
If you want serious horsepower mast motorsports is what you want to look at. Check out threads tagged with etp or mast.
Old Mar 2, 2011 | 08:23 PM
99slobird's Avatar
Which of the mast head do u recommend?
Old Mar 2, 2011 | 08:36 PM
*02WS6TURK*'s Avatar
AFR or Some Advanced Induction's newly revised 243 LS6 heads.
Old Mar 2, 2011 | 08:40 PM
99slobird's Avatar
I need to know where to get them and maybe a part number or something lol. Just to make sure I'm getting the right thing lol
Old Mar 2, 2011 | 09:05 PM
99slobird's Avatar
I just haven't found a set for a 3.905 bore that flow more than the prc227s????
Old Mar 3, 2011 | 05:18 PM
studderin's Avatar
that makes them the best right?
Old Mar 3, 2011 | 06:01 PM
Cathedral Port 11 Degree Small Bore LS1 / LS6 CNC Assembled
there are those which are 215 cc runner. If you do a search there is a guy on ls1tech that swapped just the heads from AFRs which are a highly regarded head and picked up like 22 horse at the tire with just a head swap.
Rectangular Port LS3 11 Degree Small Bore CNC Assembled
These are if you really want to get crazy and look at the flow data its flowed on a 3.90 bore and not a 4.0 or larger like most shops rate heads with. you would need to convert your manifold with this second head but it is designed to use on your block.
Old Mar 3, 2011 | 08:50 PM
westtexasbuff's Avatar
I've heard that hookers on CList give some badass head
Old Mar 3, 2011 | 08:51 PM
NVR_SPDS's Avatar
PM Tony Mamo @ AFR, and talk to him about what your looking for. Hell be able to get you EXACTLY what you need, depending on your budget. Also, to make the most of them, dont use an off the shelf cam.. Tony would be able to spec you the perfect cam as well.
Old Mar 3, 2011 | 08:56 PM
180ls1's Avatar
I also would consider getting a custom cam to match that setup, there are more powerful cams to be had then the ms3 for your setup.
Old Mar 3, 2011 | 10:16 PM
99slobird's Avatar
Definatly leaning towards the mast head now. Thanks alot
