Quieting down exhaust
Setup: no cats, long tubes, magnaflow catback, hotcam, ported heads, z06 intake
Will adding in another muffler screw with my 02's? Will it effect performance?
Thanks~
Great product, Ive got the dual disks on my C5 with Longtubes n borla had
horrible drone and was way to loud, cops would follow me everywhere. Its still loud at WOT but at idle and below 3000 its great, people say it robs HP but I couldnt tell no seat of pants change, and even if it does you can always unbolt the pipes and pull them out anytime. Mine mounted b4 the muffler in the pipe. They have options on how quiet you want them by spot welding closed and slotted end caps on them, I did the slotted caps, u prolly could get by with-out the caps on them if you want it just abit less noticible, also you can spot weld closed caps for max sound reduction, any questions you can pm me, goodluck man. Also try looking up the cone style inserts also.
thanks man, great info. im gonna go ahead and order a 3disk. so you just disconnect the catback,slide it back in, and close it up? no welding?
https://ls1tech.com/forums/generatio...-question.html
The thread is old, but people have proven with actual dyno results that they kill power. I mean, just look at the damn thing...you shove that contraption in your exhaust, and it isn't supposed to kill your exhaust flow? This isn't rocket science, and I can assure you that those inserts don't redefine the laws of physics only in their vicinity.
ok, so weld this: http://www.ws6project.com/user_stor/...oducts_id=1141 in to my y-pipe?
how many decibles would this reduce? the cc-insert is saying 5-7. i'm assuming this would be comparable?
