Wont start video added please help (MORE VIDEOS ADDED)
Well just finished putting my motor back together, put different stock head put the stock cam back in and different intake but now it wont start now. Can it be cause it still has the tune from my other setup? I know it wont run good without a tune, but would that be the reason it dont turn on?
what it does now
http://www.youtube.com/watch?v=Czrw1OEifi4
http://www.youtube.com/watch?v=2ulYD1Rpsx4
removed the 3 ground from the ds heads
http://www.youtube.com/watch?v=sQuc4WNTUfw
started up cause gas was in the chamber
http://www.youtube.com/watch?v=Igxi9lUOkdo
what it does now
well found out why it was just cranking and not getting spark to the plugs 6 of 8 coils where bad (arching) well replaced all 8 of the and now it get sparks and turns on but just turns right off here a video of what its doing pleas help me out. still has not been tuned
http://www.youtube.com/watch?v=avsjzaIVRCk
it should still run without a good tune. sounds like a vats issue to me or... when you installed the cam and timing chain did you make sure that the gears were lined up dot to dot? could be a tooth off?
