eps 226/234 cam and tfc 215 heads questions
![Smile](https://ls1tech.com/forums/images/icons/icon7.gif)
i decided on my head and cam combo im going with a eps 226/234 cam with tfc 215 heads. what do you guys think of this combo. has anyone done it if so what did you make. what size head gasket should i use. how is ptv with this i was told they are good not to wory. tfc heads ahve better ptv. its should make 470hp 440t. i am using ls7 lifter and ls2 trays. are they a good choise with the cam. and 1.7 roller rockers. what sould my pushrod length be. thanks any help and info greatly appricated.
Stock LS2 with ported and milled heads (64cc) and a .045" gasket and the same cam had .090" ptv on the intake. I do believe the TFS heads offer more clearance, but its always best to check. Call Geoff as I recall he did your exact same combo on a stock ls6 motor and made 470rwhp.
I'm going with a EPS custom cam on my new motor. I was using a Futral cam with those heads and a ported fast 90mm intake and went 10.90@123mph on a full weight stock suspension Z28.. I am selling that cam if you are interested.. The specs are 232/236-646/612@114
BTW this was a stock bottom end LS1..
