Any One Having Problems With Comp 918 Springs
I'm only spinning this motor to 6400 so I can't say if they'll hold up to those who spin higher?
I tend to believe that proper/inproper set up on ANY head(as mentioned above) as well as heat cycling of these(or any) spring is going to make a difference in how long the spring will live. Why wouldn't you back check someone elses work, or any drop in item? Nobody/nothing is(always)perfect. Josh B. can attest to that first hand <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
On a side note(no flames intended), why are those who are running higher lift cams, and SI/SII heads not having the seats cut for dbl. springs? It only takes an hour or less per head and the added cost of a dbl. spring, giving you the peace of mind knowing there will be no float issues, not to mention not having to always wonder if these dainty single coil units are gonna self destruct?
<img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" /> TEA is cutting the seats and using doubles on ALL their heads. Hmmm....wonder why........ <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
