what is this? i want it gone!
I will remove it when the time comes and not look back. I want it out cause it clutters the **** out of my engine bay and theres no use for the clutter cause i like working on my own stuff and its pointless to have to move all that ****!
I took all the crap off my IROC and loved being able to work in there!
If u plan on keeping the stock intake.
A parts store 1 3/8 brass or steel freeze plug can be tapped squarely in place with large socket. Tap in place about .125 minimum. Seals perfectly no leaks if done correct. This was like one of my first mods on a ls1 intake back like in .99'
OH and I wasnt trying to be rude to the OP but honestly If you take some time and read this forum there are tons and tons of stickies and first mod sections that cover removal of EGR/AIR/LS6 intakes etc.. etc... you dont even have to search just look through the forums. Have fun and enjoy your stay.
all the yellow threads (which are "stickies") should have more than enough info to answer questions like the OP had here.
The purpose of EGR (Exhaust Gas Recirculation) is to reduce the NOx emissions. Air is mainly made of oxygen and nitrogen (O2 and N2). At temperatures above 1300°C (2372°F), these molecules split apart and rejoin with each other to make nitrogen oxides (like NO, NO2, etc...). The nitrogen oxides contribute to smog formation.
EGR puts a portion of the exhaust gas back into the intake manifold, so it mixes with the fuel and air. (Note that the exhaust adds to the fuel and air; it doesn’t replace any of it). The added mass in the cylinder is harder to heat up, so the combustion events have lower peak temperatures. The lower temperatures prevent the O2 and N2 from splitting and combining. Even though the exhaust is hot, about 600°C (or 1112°F), it's much cooler than the 1300°C required to make NOx.
In summary, the exhaust adds mass, increasing the heat capacitance of the mixture (i.e. making it harder to heat up the mixture in the cylinder). Peak temperatures are lower, reducing NOx formation, which ultimately reduces smog in the environment.
The reason EGR improves fuel economy is because it reduces the engine's pumping losses. For the cylinder to move down on the intake stroke, the piston is working against the intake manifold vacuum. Another way to say it is that the vacuum above the piston tries to prevent the piston from going down. EGR increases the mass in the intake; more mass means higher pressure, or less vacuum. Now the piston has less resistance during each intake stroke, which results in better gas mileage.
Its exactly what I said but I said it in 2 sentences. Improved gas mileage due to less vacuum against the intake stroke? wow, really splitting hairs here. Maybe that will increase your fuel mileage by .00001% but I dont buy it. I think I could save more fuel by being less aggressive with the pedal or maybe driving with the windows up rather than down.
What would you say to the engine being more efficient with a cleaner a/f charge in the cylinder while cruising. Producing more usable energy with less demand from your foot... The EGR is not forced into the cylinders its introduced into the intake and drawn in by each cylinder so therefore you will get less oxegen in the cylinder and less burnable air, producing less power at crusie per the same amount of volume being drawn into the intake. The cylinder will only allow what the head will flow into the cylinder. If whats in the intake is part fresh air and part Exhaust gas you WILL get less fresh air (02) into the cylinders.
Nice theory you copied from somewhere though...
All the NOx info seems to be accurate. Last edited by Mart00SS; Mar 26, 2011 at 04:31 PM.
We should have just wandered around the university asking questions instead. "What's a differential equation?" "What's an antigenic determinant?"
Differential equation:
A differential equation is a mathematical equation for an unknown function of one or several variables that relates the values of the function itself and its derivatives of various orders.
