HELP!! Not building oil pressure TWICE in my LS6!
Pulled the pan off and what do u know it was the o ring in the pick up tube wich was pinched . So going to put a new one in . Fresh mobile 1 and filter and see how this goes...
So you'll also want to hold the pickup tube up against the pump housing while tightening the bolt, not using the bolt to pull the tube into place.
So good luck!
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
