??? 5.3 ironblock help please???
Old Apr 5, 2011 | 11:54 PM
CHV.408's Avatar
Default ??? 5.3 ironblock help please???
Hi guys hopefully some one can tell me the 5.3 litre (3.75' bore) out of the pick ups is it the same engine as the 6.0 litre (4.00" bore) other than the bore size and how far is it possible to bore one out? any help greatly appreciated..
Old Apr 6, 2011 | 08:21 AM
MIKE93SVT's Avatar
just use the search button. lots of threads. same crank and rods, different bore size and cylinder sleeves. don't bore them past 3.905
Old Apr 6, 2011 | 09:21 AM
parks450's Avatar
The 6.0 doesn't have the same crank and rods just the ls1 and 5.3 do. I did mine to 3.898 bore with no problems. I wouldnt go over that though.
Old Apr 6, 2011 | 12:05 PM
KCS's Avatar
KCS
Moderator
Not all, but most 6.0L iron block engines do. Regardless, you can use the crank and rods from a 6.0L in a 5.3L, as long as the pistons are adequate.
Plus, I've heard of people boring the iron 5.3L's further than 3.905" with great success...
Old Apr 6, 2011 | 04:22 PM
parks450's Avatar
You push over 3.905 your asking for trouble. Wouldnt be reliable in my book.
Old Apr 6, 2011 | 04:30 PM
KCS's Avatar
KCS
Moderator
Have you ever done it?
Old Apr 6, 2011 | 04:52 PM
kinglt-1's Avatar
Found this thread on pg. 2....
https://ls1tech.com/forums/generatio...ore-5-3-a.html
Old Apr 6, 2011 | 09:59 PM
parks450's Avatar
Cant say I have. But I personally wouldnt I just wouldnt feel comfortable doung it is all. Just my opinion
Old Apr 6, 2011 | 10:15 PM
swift700's Avatar
I just bored mine out to 3.907. There was a minimum wall thickness of .110 and went as thick a .175 I believe. Still thicker than a 350 small block bored .060 over, and that's with taking an eighth of an inch out of there.
Old Apr 10, 2011 | 02:40 AM
chrisfrost's Avatar
What I've read on here is although the 5.3 , 5.7 and the 6.0 share the same stroke all 3 use a different crank because of the different weights of the piston, pin, rod assemblies . Boring a 5.3 iron block usually can easily take 3.905 or more . To be sure have the block sonic checked for peace of mind .
Old Apr 10, 2011 | 10:03 AM
CodyBoy's Avatar
New here with 2 whole posts.
The block on my 5.3 has "4.8/5.3" cast into it on the front left. Is the 6.0 the same block too?
Old Apr 10, 2011 | 11:10 AM
DLuke's Avatar
No. 6.0 is different. It would have "6.0" cast into it.
Old Apr 10, 2011 | 09:08 PM
tonytone4143's Avatar
so i guess you can bore it out to a 4.0 bore?
