PAC 1518 recall / breaking??
My batch number:
36822 82310
Mine I believe on march 2nd. They have been on the car for almost 1k miles so far without a problem.
wire to reduce imperfections which could cause cracks and it helps the oil
drain off faster removing heat to extend spring life. These were designed
originally for ls stockcar racing (ASA) used by Lingenfelter and Wegner Racing
when they had the GM account. I've heard they last forever even w/today's
more aggressive lobe profiles. FWIW @370 lbs open .625 lift...if your cam has
.610 theoretical lift....factoring in deflection....a dial indicator would show the
retainer is only moving .590 and springs usually lose some pressure after a few
heat cycles so you'ld end up @ around 320-325 open pressure.
but rather developed a spring with exceptional endurance qualities as needed
in stockcar racing. The only LS racing series I knew of that existed was ASA
to which I know you guys freshened the engines. I suppose any spring other
than the GM may have been a rules infraction however someone @ Wegner
did tell me they used them. I was only trying to suggest an alternative B hive
since I see threads about other brand names having occasional issues
maybe due to todays more aggresive lobes....not sure......
again I apologize for my improper statement
Thats the same batch that have just been installed on my engine, i sent an e-mail to PAC but they didn't bother to reply, i gave them my batch number.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Currently have a 260/264 .685/.685 in there now with PAC beehives, it goes over 7000rpm reliably....
