TEA LS6 Stage 2
Old Mar 29, 2011 | 08:49 PM
intenseblue's Avatar
Default TEA LS6 Stage 2
Just ordered a set of these last week and they came in today. These cylinder heads look amazing and Mike from TEA was awesome to deal with. I wanted to post up flow numbers for those that might be interested as I was a little surprised. Hope they make good power, my new setup will be done about two months and I'll update with dyno numbers and track numbers. Going to these from a ported set of 853s Hopefully they'll make a noticeable difference. These are 62cc's. How much was taken off from milling was not listed on the paperwork, but I believe that it was .025 from talking to Mike last week. Anyhow, here are the flow numbers...
Intake
.100--70.1
.200--139.7
.300--216.1
.400--269.9
.500--309.7
.550--319.3
.600--326.1
Exhaust
.100--59.0
.200--121.5
.300--181.5
.400--240.3
.500--261.6
.550--267.7
.600--271.2
Old Mar 29, 2011 | 10:18 PM
SOMbitch's Avatar
Intake
.100--70.1
.200--139.7
.300--216.1
.400--269.9
.500--309.7
.550--319.3
.600--326.1
Exhaust
.100--59.0
.200--121.5
.300--181.5
.400--240.3
.500--261.6
.550--267.7
.600--271.2
That is awesome and flows better than my touched up TEA TFS 220's above .500
For some reason their exhaust numbers are always jacked up (mine too) so not sure how to explain it....... even when I see them flowed with a pipe TEA #'s seem high...
Congrats they are the cream of 243's with only 2-3 others IMO....
Old Mar 29, 2011 | 11:11 PM
99 Blue Bird's Avatar
post some pics. someday i will send in my 799s for a TEA port job.
Old Mar 30, 2011 | 08:48 AM
Quick shots this morning. First time trying to get pictures of ports. Kinda difficult to lose the shadow effect.
Attached Thumbnails TEA LS6 Stage 2-photo03300923.jpg   TEA LS6 Stage 2-photo03300924_1.jpg   TEA LS6 Stage 2-photo03300926.jpg   TEA LS6 Stage 2-photo03300927.jpg
Old Mar 30, 2011 | 04:47 PM
N2OBaby's Avatar
Question
Your heads look great but how much they set Ya back?
What engine are they going on?
Old Mar 30, 2011 | 05:58 PM
_GTO_'s Avatar
Are you running this on 3.9'' bore or 4.0'' ?
If 3.9'' , which head gasket is required to use with these heads?
I know people have used 4.0" bore head gasket on their LS1 due to the big intake/exhaust valves.
Nice choice , congrats .
Old Mar 30, 2011 | 06:12 PM
90k stock bottom end LS1
TEA Stage 2 heads, stock MLS gaskets
.595/.598 232/234 112LSA+2
LS6 oil pump, LS7 lifters, NMotion adjustable timing set
Fast 90/92 as soon as I find a good deal on one
FTP 98mm lid + 85mm Delphi MAF
Kooks 1 7/8" + o/r Y
Magnaflow catback w/cutout
ASP underdrive pulley
Ram Powergrip HD
4.10 gears in stock ten bolt
Old Mar 30, 2011 | 06:15 PM
I now people have used 4.0" bore head gasket on their LS1 due to the big intake/exhaust valves.
Stock LS1 gaskets or Cometics can be used for a 3.9" bore I would think. I don't know for sure how large you can go. Plenty back in the day use to use the 2.055 valves with stock gaskets IIRC
Old Mar 30, 2011 | 07:58 PM
chrs1313's Avatar
yeah 3.910 cometic here works fine with my 2.04 intake valves
Old Mar 31, 2011 | 08:29 AM
bigboykilroy's Avatar
TEA did mine a few years ago (09), 243 Stage 2 61cc chambers here are my numbers: (here are my before and after TEA https://ls1tech.com/forums/generatio...d-numbers.html)
(I have a 98 block these are the MSL GM Gaskets I used No issue at all NAL-12498544)
.100...67.0...56.9
.200...137.6...123.0
.300...216.0...181.6
.400...269.2...233.7
.500...308.7...256.6
.550...321.4...262.3
.600...327.5...265.2
