EPS cam with PRC stage 2.5 5.3L heads?
Is anyone running, or planning on running an EPS cam with PRC Stage 2 5.3L heads? The reason I am asking is because it seems everyone is matching EPS lobes with LS6 heads and making good power.
I would like to run ported heads for the higher flow rates but I'm a bit turned off from PRC LS6 heads with the 235cc intake runners. The PRC 5.3L heads have smaller intake runners (220cc?) that would probably match my 230/238 112+2LSA cam quite a bit better and the lower price & additional compression would sure be nice
. The only problem is that I don't know if the runner shape of the 5.3L heads vs. the LS6 heads would "affect" what makes EPS cam make so much power and torque. Is there still a difference in LS6 vs. 5.3L runner shape after porting is complete or are they nearly identical?
Any input is apreciated! Hopefully GEoff or TSP can chime in as well...
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Thanks for the correction... I guess I should have paid attention to the dates of posts from you guys saying 237/230cc etc. Appears it was changed to 225cc in 2008... this definitely helps w/ my decision, I want to keep those velocities high!
