lq4 w/ milled l92s pushrod length question
My set up: LQ4 w/ .030 milled L92 heads & 02-04 LS6 cam and 6.0/6.2 MLS Gasket .051 thick, stock lifters, comp cams adjustable pushrod checker, .1 for preload.
I'm having a horrible time trying to get a accurate pushrod length, I had problems doing it for my LT1 and now its back for my LS motor.
I tried the 'tick method,' where you put it to TDC and adjust until the 'tick' is just gone. I consistently got 9 - 9.5 turns to make the 'tick' go away. I also tried the method in the cam guide stick where you mark the valve tip and check the pattern after it turned over but it was never consistent and I had markings all over the place and could never get it to center. I also read about the 1-1/2 turns method, tried that and never got more than 1/2 turn in the range of 8-10 turns of the adjustable pushrod tool.
I know that the 02-04 LS6 cam uses a 7.425 pushrod in a stock motor, how much would milling .030 affect that number because right now I'm looking at a 7.35 pushrod (based on the results I got)...
i'm putting together a simalir combo, asked a few people with lq4's with l92s milled .030, stock l92 gaskets (051). and they all said 7.350
so you're on the right track. this was with stock rockers
I've got .032 milled Heads, .040 Head Gasket, but a Comp Custom Cam. I was told that 7.4's were good for my setup when it had the Heads at .025 mill. I'll have to check when I get it back together.
The base circle on the stock Cams is larger than what my Comp is, that is probably why I'm able to run the stock length.
I do want to check it tho..
