What cam to get/gains to expect?
Old Apr 10, 2011 | 09:06 PM
MikeWS6's Avatar
Originally Posted by BirdsSince16
I have a feeling with only the LM1 I'll be deciding to invest in a real catback to put behind it. I've heard a lot about how obnoxiously loud it is and, while I want my car to sound like it commands authority, I want to be able to drive more than 4 minutes without getting a migraine.
Looking at your sig, do you have any sound clips? You have pretty much the same thing.
I dont have any videos so I am no help there. My setup is actually pretty civil, but I also have high flow cats. Its only real loud on wot pulls. Just driving around town its pretty tame. Now with an off road y pipe it would be MUCH louder and very obnoxious. I know this because my friend has that same setup.
Old Apr 11, 2011 | 09:09 AM
nwalton29's Avatar
Yea, I don't run a 346 anymore. When I did, it was a torquer v2(232,234). It drove good, except for the Detroit locker ratcheting with the clutch in while turning in a parking space. If I ever stick the motor back in, I'm going to use something close to an ms3.
Old Apr 11, 2011 | 10:23 AM
brian_rs/ss's Avatar
I read the cam guide, and was planning on single springs, just wanted to double check on the size.
I don't remember seeing anything about EPS or XER lobes. Can you link a thread or tell me more, plz?
yeah hold on i'll post some EPS dyno threads and XER dyno threads.
Old Apr 11, 2011 | 10:51 AM
here EPS results. if you go search the dyno section you can find literally hundreds of xer dyno results. i'de post links but it's gym time. sorry.
https://ls1tech.com/forums/dynamomet...ts-update.html
https://ls1tech.com/forums/dynamomet...s-results.html
https://ls1tech.com/forums/dynamomet...o-results.html
Old Apr 11, 2011 | 01:20 PM
intenseblue's Avatar
That cam is proven multiple times on XE-R lobes and will NOT be 20hp/10tq shy of an EPS lobe.
