DIY crank pulley installation tool?
One of the best tools ever made.
It's only 2 or 3 minutes' worth of extra work to do it right. To take a shortcut could mean going back and doing it all again when the balancer is walking off the crankshaft.
I used an ARP balancer bolt which gets installed at 240lb-ft, not a relative 140* angle after 37lb-ft. I still used the original bolt to ensure seating, removed it, and installed the ARP. Peace of mind following the field service manuals.
I have an ARP bolt. Do I still use the stock bolt to set the pulley, or can I just use the install tool to put the pulley on, and put the ARP bolt in, and torque to 230ft/lb and call it good, and never have to put the stretched bolt back in?
If your using an ARP bolt, thread the balancer all the way on, install the bolt and torque it! Done.
USE A GM INSTILLATION TOOL OR EQUIVALENT
OR USE A THREADED ROD OF PROPER PITCH AND SIZE WITH A TORRINGTON BEARING WITH HEAVY BACK UP WASHERS.
Never heat it
Never use the stock bolt it is to short and TTY
Both of these procedures can ruin a damper or strip the threads in the crank faster than you can SPIT!!
Proper tools are a must. Especially with the damper. Just me could be wrong!!
To answer your question
-After the balancer is fully seated, torque the ARP bolt down per instructions and you will be good to go. If I recall its 240ftlbs and you will be hard pressed to get it that far. Most people just get it to 200 or 225 and call it good.
Here is my install process, following the GM manual. No lubrication on pulley or snout.
1. Balancer install tool (thread-rod or Kent Moore equivalent, NOT the old bolt) which has full crankshaft engagement to draw the pulley as far as you can. Ideally to within the Service Manual's range of fully seated (snout recessed 2.40-4.48mm). The old bolt does not ensure adequate crankshaft thread engagement, and is asking for trouble as everyone else has stated.
2. Once it's close, remove the installer tool then use the old bolt one last time to Tq to 240lb-ft. This ensures full pulley seating. Take this bolt out, and chuck it.
3. Install new bolt to spec, either the OEM TTY bolt or ARP. My step 2 is required for OEM, and may be optional for ARP. However I would rather spend/waste the extra 2 minutes to perform step 2 following the GM process when installing the ARP bolt.
Just curious why does the factory not do it this way!!!!
First off the snout and damper should be well lubed before pulling on the damper with the GM tool or equivalent on the crank. This is not BRAIN SURGERY.
THEN
Install your new bolt and tighten to 37 ft/lbs.
This step is to get a reference on the front of the engine. With the torque wrench hanging at the spot where the 37 ft/lbs was achieved, reference 140° clockwise for another tightening cycle. Put a mark or a piece of tape where you need to tighten.
Then go another 140° from the 37 ft/lbs start point and you are now tight. (We also recommend Loctite here if you are doing any High Performance Driving with this engine.
For an aftermarket ARP Bolt use Red Loctite and tighten to 250 ft/lbs.
This is how we do it and it works just NIFTY. Heating is a NO NO plain and simple. But if it works for you OK. This is not something that takes a lot of thought. It is not brain surgery by no means.
99055a239 - M16 x 2.0 300MM in length ($13.60)
92497A600 - Nuts M16 x 2.0 Pack of 10 ($8.14)
Cut the threaded rod in half, weld 1 nut to the end of each piece, install a 2nd nut and use some washers as well. I can add a pic of this tool this evening.
threaded rod a nut and a washer is all you really need.... you can use a pair of vise gripe to hold and turn the threaded rod if need be... a cap/acorn nut of the back of the threaded rod is used for screwing it in and out.. I also have the tool I bought a long time ago I lend out
I bet a beer, GM did not install a bolt, tighten it, loosen it, and toss it to install another bolt for final assembly....
You will know when the balancer is all the way on.
