Cam or N2o ???
You will for get all about the extra 3-4 months wait when you hit the switch >)I did all my stuff at different times and end the end I had to pay for 3 tunes! That would have went along way towards another mod!
is it a plate system or a universal? i would suggest grabbing a 78mm plate from n2o outlet, a bottle heater, and a bottle opener. then before you spray it have it dyno tuned. you will also need to swap out your stock plugs for tr6's.
save your money, peice together a plate system like i said before, and then finish grabbing the few extra things you need for your cam kit. take it all to the shop at one time, have them install it all and tune it all in one swoop. your over all labor bill will be cheaper. (or install everything yourself then have it tuned all at once) either way it will pay to be patient.
btw i hope i you have a savings fund set up for when that rear end pops. and iiwy i'd replace the timing set and oil pump when doing the cam swap.
